Question about Toro Lawn Mower With Toro Power Tools
Screeching snow blower
I have a Toro ccr3650 snow blower It isnt throwing any snow adn screeches, is there a belt or something that can be adjusted?
    Scholar:
  • 76 Answers
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
Posted on Jan 15, 2009
Hit piece of wood unit popped and quit. wont start now.unit is toro ccr3650 snowblower
check the shear pin under the fly wheel it sounds like you have sheared the shear pin
Feb 16, 2015 | Garden
Wont throw snow is there a belt adj
the idler pulley might have a slot to adjust more tension
Feb 17, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
My snowblower does not seem to run at full speed. Barely throws snow recently. Any adjustments I can make?
There is a spring attached to the throttle linkage. At the other end is an arm that the spring attaches to. Bend the arm so that the spring is tighter and it will throttle up higher under a load. Don't go too far or you will take a chance of blowing the engine. Best to use a rpm tester and set it to factory specs.
Feb 22, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
The engine starts but won't actually throw snow the wheel that turns to throw snow is not turning
There is probably a shear pin or bolt that has broken, providing all other belts and accessories are intact. Should be very simple to take the bolt out of the wheel where it attaches to the shaft. Just take it to a hardware store or an outdoor store that sells snowblowers.
Feb 17, 2010 | Toro Lawn Mower With Toro Power Tools
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Auger belt on snow blower keeps coming off
if shop just repaired it, go back. Right belt? Tensioned enough?
Jan 28, 2009 | Toro Blowers Rake and Vac - Electric...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Toro Lawn Mower With Toro Power Tools Logo
402 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
