Question about HP Color LaserJet 2600n Printer
HP2605dn will not print
HP2605dn is out of the 3 color toners but has black, still will not print in grey scale, is this normal.
  • rdimascio3 Jan 17, 2009
    Thank you for your help. I replaced the cartridges and all is well.
    Genius:
  • 1,605 Answers
Yes, it is normal
the newer printer has senser for ink cartridge. printer will not print if any of the ink cartridge is empty.
therefore, you need to replace the emply ink cartridge in order to print.
Posted on Jan 14, 2009
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
Hp color lasejet not printing color
check the color settings is grey scale or not. if its grey scale change to color then it will print color . if you have limited knowledge only about printers then do one thing download the latest device driver & i am sure this will solve your problem 100 %.
driver download link: http://url2it.com/betkd
Please rate my answer.
Sep 17, 2012 | HP Color LaserJet 2840 All-in-One...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
My colored cartidge is out and my black is full. I went in under maintenance and changed it to balck only and printer preferences and changed it to grey scale. it still wont print black only
Some printers simply will not work if one of the cartridges is empty, even if you are not printing with the cartridge. The other catch might be is that some printers create grey scale by mixing colors so you might want to turn off grey scale and try printing just black and white.
Apr 13, 2011 | Computers & Internet
My colored ink needs to be replaced, however, I still have black ink, why will the printer not let me print in black and white, there is no grayscale.I can't print at all unless I replace the colored ink.
The issue is the printhead needs constant flow, I have seen bypasses but this damages the print head and all kinda of mess happends. The solutions here is a grey scale laserjet if your only use black ink. Your would be alot better off because this printer mix inks to make black and vice versa, So you need to fork out the bucks for the color cartridge or change the solution to toner if you do not use color. Yes there is a bypass but we are not aloud to provide that because it will dmage you unit and we cannot be liable for that Google is your friend!
Thanks and please do be considerate and leave postive ratings and feedback for your free answer today.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer is only printing grayscale, need color, hp deskjet 6340
This is either because: 1. You only have black ink remaining and your tri-colour cartridge is empty or 2. In the printer driver settings you have selected either: Print Grey scale or Use black only.
I beleive your problem might be the last option.
To fix it :
1. Go to the printer driver (in vista go to: Start, Control panel, Printers, right click on your printer and select "printing preferences"). Now you are inside the printer driver. 2. go to the "color" tab. 3. Tehre you'll see if you have selected wither "Print in grey scale" and/or "Black only". 4. To ensure you get color again, de-select the"Print in grey scale" option.
Cheers, Ed
Oct 04, 2009 | HP Deskjet 6940 InkJet Printer
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
Writing in grey scale
Make sure that in the printer driver that print the text as gray scale isn't checked and that the toner saving mode isn't on. failing this you may have a faulty machine return it to the store and get an exchange.
Hope this helps
Thanks J
Jan 13, 2008 | Samsung CLP 300 Laser Printer
Brother MFC-620CN Printer
my brother mfc-620cn printer is printing backwards if you had a see threw paper itnwould look right
Jan 26, 2007 | Brother MFC-620CN All-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
109 people viewed this question
Ben Johnson
