Question about Polyserve Matrix Server (372747B21) for Linux
Filename limit on Linux
We're implementing Polyserve on Oracle/Linux RAC environment, please let me know if there is a solution for that. Thanks.
    Novelist:
  • 153 Answers
Filename limitations are a function of the filesystem the operating system runs on. This subject gets far too involved for this forum very quickly so I will refer you to http://en.wikipedia.org/wiki/File_system for more information.
Posted on Apr 22, 2009
Which is the best training institute in chennai?
Hi all, Now days additional software skill is required for every job in the competitive corporate environment.
sysadmin academy offering best training courses like ccna, cisco, vmware training, cloud stroage, RHCE training, red hat training etc.
RHCE Training in Chennai Red Hat Linux Training in Chennai RedHat Linux... SYSADMIN ACADEMY Linux Training in Chennai Red Hat Training in Chennai... VMWare Training in Chennai Storage Area Network IBM Array RHCSA Training in Chennai Best RHCSA Training in Chennai Sysadmin Academy
Jun 07, 2016 | Institute of Mathematics and Statistics...
Tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 | Computers & Internet
Is java add on SE Runtime environment 7 update 67 from Oracle American Inc. safe?
Hi Anon
It should be safe if you download it from here http://www.oracle.com/technetwork/java/javase/downloads/jre7-downloads-1880261.html
As always check it with your internet security software to be certain.
Aug 13, 2014 | Computers & Internet
I need the links for downloading linux and oracle!
You didn't say which Linux distro you wanted to try so here is a great link where you can find just about any distro you would want:
http://distrowatch.com/
Here is the link for oracle:
http://www.oracle.com/index.html
Jun 01, 2012 | HP Computers & Internet
Running HyperFabric in HPN4000
why not ask at HP.com and not here on the CHAT spam channel.
here is the real place to ask HP questions, its called HP.
they will send you to the BUSINESS section (servers)
my guess your first HP ever?
https://h30434.www3.hp.com/
Jun 24, 2017 | HP 9000 N4000 (A3639A) Server
Unistalling Oracle
You will need to re install it and then uninstall it for cleaning it completely, but it will still shows information in registry as long as registry does not deletes it after few months.
You can also manually delete it from your program file folders.
Sep 11, 2009 | Oracle Database 10g
Access sql database using C.
Please go for the ORACLE 8i or higher, it has a utility called proC, in proC you can create program to access any database in Oracle or SQL server.
After compiling program in proC environment, it will create C code for tha same logic, that you can compile and use in C enviromnent
goodluck
Zulfikar
Mar 10, 2009 | Computers & Internet
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Scanner problem
Hi BethKay,
What it's telling you is that the "filename" that the scanner/software package is trying to use to save the document being scanned to your hard drive has reached it's limit in the amount of times that it can be incremented by "1". In other words every time you scan a document it is saved to a directory or folder on your PC under a filename which is probably assigned by default. This filename has a "suffix" which is also assigned by the scanner/software eg. filename01.tif (or jpg, etc) filename02.tif filename03.tif and so on. Either I'm way off base or you must have scanned a whole bunch of documents using this naming convention because the scanner/software has run out of numbers that it can affix to each individual file. What you need to do is either 1. Change the folder that you are saving the documents to or 2. Change the pre-suffix filename in order to retain individuality.
Make sense?
Let me know if this helps and good luck.
J
Feb 22, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Computers & Internet Logo
351 people viewed this question
Top Polyserve Computers & Internet Experts
David Payne
David Payne
Are you a Polyserve Computer and Internet Expert? Answer questions, earn points and help others
