Question about Kenmore 44102 Front Load Washer
Loud spin cycle/water leaking
My washing machine had sudden become very loud on the spin cycle. I have noticed water on the floor a couple of times also. What could be causing this noice? Some type of bearing? And is this something I could repair myself.
  • 1,031 Answers
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Posted on Jan 14, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 14, 2009
    look for water leaking from the center area just above the transmission. Often the transmission is covered with staining from the leak
    Look in this area for the leak
    hope tis helps pls appreciate by rating as fixyaa
Frigidare Gltf1040as0
Good Afternoon Carrie,
I understand that you are hearing a loud noise in the spin cycle as well as water leaking from your Frigidaire washer, model# GLTF1040AS0.
You will commonly hear a high pitched "jet engine" noise during the spin cycle. If you are hearing a vibrating noise, it could be your washer is not resting firmly on the floor. With this you will adjust the leveling legs so the washer is level. If after leveling your washer you are still receiving a vibrating sound, you might want to redistribute the wash load inside your appliance.
If after you redistribute the wash load, you are still hearing a loud noise in the spin cycle, I suggest contacting a local authorized technician.
For the leak I recommend contacting a technician. This way they are able to find where the leak might be coming from and repair it before there is any damage done to your appliance. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire Washing Machines
Loud Bang at End of Spin Cycle; Leak Underneath Washer
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
Jan 21, 2013 | Maytag Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
Jun 13, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Maytag SAV205DAWN, loud and leaking!!
the main seal is leaking and water has goy into the bearings,needs to be stripped and rebuilt
Nov 09, 2017 | Washing Machines
Spinning loudly, drum seems loud when washing
bad bearings , if you have good habilty with your hands you can do it. couple of tools , order the parts , job done. let me know how much help do you need to perform the job or if you prefer call a tech , you now already know what its wrong with it thanks
Jun 13, 2007 | Hotpoint WMA40 Front Load Washer
Kenmore 44102 Front Load Washer Logo
557 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
