Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
My Sub-Zero 611/O is not cooling enough. The temp is 0 in the freezer and 46 in the fridge. I vacuumed very well the condenser. I can't tell which compressor is running. There are two, one larger than the other. The fan is running non stop. Last month there was every day a frosted area inside the fridge of about 6 inches in diameter and up to 1/4 in thick. I would remove it by just pulling it away from the rear panel of the fridge. There was a lot of moist and sometimes even some drips. The frost is located in the rear panel all the way to the left side half down from the top panel were the on/off and control temp buttons are. My wife does open and slams the door about a million times a day. Please Help me!
    Scholar:
  • 58 Answers
You have a hole in your evap coil in your fridge. What your are going to have to do is call a authorized service company and get it fixed. you will need a evap coil and a filter dryer and depending on how long your unit has been running maybe a compressor also. when ever there is ice on the rear wall on the left that means you are low on freon and sub-zero is very common on it's evap coil. Now as long as you get a subzero authorized company you will be able to take advantage of your warranty you have a 2 year full warranty, 5 year parts and labor warranty, on sealed system( what you need). and a 12 year sealed system part warranty, if your under 12 years you only pay labor. Hope this helps you
dmparenti
Posted on Jan 15, 2009
    Problem Solver:
  • 11 Answers
More than likely the fan inside the back of the unit freezer compartment is not working and causing the freezer to freeze up.need to pull pannel off inside back of freezer and replace fan
Posted on Jan 14, 2009
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
I have a Sub Zero 601 R refrigerator. I recently noticed that it was not cooling below 45 and the vacuum condenser light was on. I cleaned the condenser and it still stays between 46 and 49 degrees.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 11, 2011 | Sub-Zero 611 / O Bottom Freezer...
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
http://safemanuals.com/zearchres_663.php
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 611/O not cooling
sorry but i do not have experience with hte sub-zero product line, I can reccomend to you thought that it is a very expensive piecce, and replacing it ( with another sub-zero) may prove to be a more costly option then the repair, Generally a Qualified subzeroe technician, (at least inmy area) is strictly a SubZero, specialist, so although you may pay a premium for the service it will be backed by the manufacture, and only 6-7 years old i cant imagine a problem that would justify replacing the unit.Althougth Im a Do-it-your self advocate, there are somethings that are generally best to leave to a professional opinion. This would be my reccomendation
Jan 17, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
392 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
