Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
Has good water flow at door,no water to icemaker.icemaker switch is on,we have no book.evidently solenoid valve is either getting no signal/or not working?what problem is most likely?Claude
  • 2 more comments
  • mscindylu Jan 31, 2009
    Our Kitchen aid superba ice maker isn't working either, yet there is water flow to the dispenser on the door HELP!
  • Anonymous Feb 01, 2009
    My ice maker is not making ice and the red light is blinking on the off off switch. I don't have an owners manuel and was wondering what to do?
  • Paul A Feb 03, 2009
    I have the same problem with the ice maker suddenly not working but there is flow to the water dispensor.
  • diannaedavis Feb 11, 2009
    Must be a sudden epidemic, anyone try the rec. solution with success??
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Posted on Feb 13, 2009
This just happened to us and the icemaker tube (black tube coming from the roof of the freezer) was frozen. We changed a water filter and apparently did not run enough water through the new filter, the black tube that puts water into the white ice tray had ice coming out of it. Additionally, there was one frozen cube in the first slot of the tray. We heated wash cloths and placed on the tubing until the ice melted. We did the same for the tray and the water began filling again. Hope this helps.
Solution #2 was the same for us. the black tube delivering water to the ice tray was frozen. we use wash clothes wet with hot water to unfreeze the tube and now it works great! Good luck.
  • 218 Answers
The prime suspect would be the solenoid valve. Check it for continuity with an ohmeter (after unplugging the fridge and disconnecting the coil, of course). If that's okay, then you might have a bad switch in the icemaker itself, or the supply line might be frozen. I'm betting on the solenoid. Good luck with the fix!
Posted on Jan 27, 2009
  • John Grimes Jul 04, 2013
    Where is the solenoid located?
Refrigerator model kscs25inssoo. Don't stop filling ice box in the door
you have a problem with the optics--if you look on the inside wall of the freezer section on the left side you will see a eye with a flipper on the left is another eye with the icemaker on off selection when ice reaches that level in the bin it cuts off a laser beam that runs from one side to another which stops power to the icemaker---clean both sets right and left eyes and unplug the fridge for 2min this will reset the optics--if problem still persists you will need new optics-part#-4389102
Mar 27, 2012 | KitchenAid Refrigerators
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaide fridge icemaker is not working at all.
Check the water flow at the door.
If the water flows slowly, then you have a clogged water filter.
The filter is either outside below the doors, or in the upper right side of the refrigerator side.
Good Luck!
Jan 03, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice cubes stick together as though too much water is coming into tray. Is there a valve or something to control amount of water coming in?
yes their is a water valve , 2 things it could be your valve or you i/m. the i/m tells the water valve to fill for about 6-9 seconds if the icemaker is bad it could be telling it to fill for 10 seconds instead of the normal time and overflow the icemaker ,or the water valve also called solenoid could be bad and at not stopping at the desighned time. i dont have your model # to go much furthur but you can remove the cover in the front of the icemaker and see if you see an icemaker water level adjustment screw, newer ge and frigidaire ref. cannot be adjusted, however wpl, maytag, and older ge ref can be and older frg.try adjusting water level at icemaker first .
Sep 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Ice Maker Not working
three things, frozen tube, deffective water valve ine maker issue
step 1 remove the rear cover of the ref down at the compressor
the water valve will be on the right side held in place with 2 1/4 inch screws
slide the valve out of the ref
the water lines connected to the valve for the water in the door and the ice maker are held in place by a retaining ring to remove the line push in on the white retaining ring and pull the ice maker line out, blow through the line into the icemaker if you can it is not the problem
with the line to the icemaker still disconneced reverse the wiring at the water valve, the connections are different is size and all that you need to do is touch the connectors on the valve while someone depresses the water in the door if water comes out the valve is good
the problem if the other tests are good is a faulty ice maker
May 20, 2008 | KitchenAid KSCS25FKSS Side by Side...
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
805 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
