Question about Brother MFC-9420CN All-In-One Laser Printer
2 black streaks on copies and faxes
Only on documents that were fed through the auto doc feeder. Any suggestions of where to start looking as to "why".
  • Anonymous Mar 26, 2009
    That removed one of the lines, still can't find where the other one is coming from.
  • 215 Answers
Open (lift up) the document feeder. on the left side of the large glass, you should see a thinner, narrower piece of glass. sounds like you have white out or something like that on that glass.
hth,
razors
Posted on Jan 29, 2009
Streaks on copies when original is fed through Imageclass MF 4694 top feeder; doesn't happen when on flatbed
There is dirt on the ADF glass. Normally to the left of the flat bed glass, there is a thin glass strip. Clean it with a damp cloth.
Aug 06, 2012 | Canon imageCLASS MF4690 Multifunction...
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Document Jam
check the photo sensor for the paper fed at the doc feeder roller section you can blow this out with air or try to clean it off you could also check the actuatot arm to see if the spring has com off.. usually its down to the paper dust on the sensor
Jun 16, 2009 | Office Equipment & Supplies
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
May 11, 2009 | Sharp Office Equipment & Supplies
Dark streaks/lines (3) down center of copies
I don't know what model you're using, which would be very helpful, however, if you lift the Document feeder section where the originals are fed, there should be a narrow piece of glass, which is only used when the Document feeder is used. This must be completely clean -1 spec creates a solid line.
Mar 11, 2009 | Sharp Office Equipment & Supplies
Faxing and or copying a black streak developes, answer??
Open up the document feeder by pulling up and clean the scanner glass
Jan 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Black lines showing up on documents fed thru the document feeder.
Clean the small glass under the doc feeder very very well...
Jul 03, 2008 | Sharp AR-M277 All-In-One Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
138 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
