Question about Lexmark X5470 All-In-One InkJet Printer
Can I fax using my home phone number
I have a Canon M5550. I want to fax using my home phone number. Is this possible?
    Genius:
  • 1,605 Answers
Yes! you can use any phone line to fax. if you want to receive fax, then you need to setup the machine to receive fax after the pre-define number of rings, and your home phone number.
Posted on Jan 14, 2009
Canon mx 410 fax answers voice calls
I have an MX870 with the same problem - fax picks up during a voice call and I can no longer hear the caller. As with everyone else, the problem is intermittent and not replicable.
I have tried tel priority mode and fax priority mode (from the phone/paper submenu under physical Fax button) and all the various RX receive setting under Fax Settings submenu of the physical Settings button.
But I have a new possible solution. I only use the fax for outgoing -- for some time now I have been using K7.net for incoming faxes which delivers faxes to my email. That way I have a dedicated fax number, never miss an incoming fax while on the phone, and I have all faxes in electronic form as well.
So, my new idea was to set the MX870 to DRPD (distinctive ring pattern) receive mode (from the phone/paper submenu under physical Fax button). Since my phone service through Xfinity/Comcast does not offer DRPD, I am hoping that the MX870 will NEVER pick up a fax.
I will keep you posted as to whether this works.
Jan 13, 2012 | Canon Pixma MX410 All-In-One Printer
I can't get my new Canon Pixma MX330 to send faxes! No matter what number I try to fax to I get a "line busy" message. This is my new home office fax! Please help!
Better check the connection at the back of your printer. This is the most common problem encounter when faxing...wrong connection.
1. when using the printer as fax, the line input should be connected properly to the "L" input at the back of the printer
2. The rj11 connector of the phone should be connected at the back of the printer with telephone label in it
I hope that helps.
Jun 21, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
No fax transmission
Plug the phone line into the plug marked L on the back, make sure you are dialing the full number, The fax won't work in an office with digital phone service, you need an analog phone line like at home. In fax setup you need the type of dialing set properly, tone or pulse dialing, check also with Canon support, 1-800-828-4040
Feb 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Fax is printing other fax machine's outbond faxes
Yikes!! Get your phone company involved. Remember that a fax machine uses a normal home style phone line. Something is seriously messy with the phone lines in the building
Sep 21, 2009 | Office Equipment & Supplies
I need to verify a received fax, but the connection tel column is blank (there is no number shown). How do I see who sent the fax at that time. There is a transaction number.. but how do I match this with...
It's possible that the originator has their number blocked (caller ID blocking). If that line is only used for the fax, I would try to learn the number using that same line and then using a phone, dialing *69 (in our area, yours may be different). If your service operates the same, you should get a voice message with the number and an offer to dial it for you.
Jul 15, 2009 | Canon LaserClass 2060P Plain Paper Fax
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Fax interrupting incoming phone call
Adjust fax machine NUMBER OR RINGS to as high as possible or buy a fax / phone switch.
Oct 14, 2008 | Canon Office Equipment & Supplies
Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Sep 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
