Do you really need to connect your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Check
the USB cable for damage and dirt, especially at the ends. Then try
using the wall charger, as this will provide greater power input than
the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect
the 30-pin dock connector at the bottom of the iPhone for dirt, lint,
and damaged pins. Clean out the dock connector very carefully with a
tooth pick or soft toothbrush. If the dock connector is broken, you will
have to replace it.
does the old computer have USB ports??? if it does than it's just a matter of connecting a USB stick and transfer the photos to it... you could also use a USB external hard drive, or a USB flash card reader, also a USB camera (the kind that taks pictures) not a web cam!!! you could even connect a Cell phone or Black berry equiped with a SD card and use those devices as a drive to transfer the files as well... you could also use the old computer to e-mail the files to your own e-mail and pick them up with an other computer by loging on to your e-mail account and save them... you could even take out the old computer's hard drive and install it in an other computer and transfer the files... When there's a will there's a way (or relatives) LOL!
Download the driver from another computer that's connected to the Internet onto a USB flash drive. Transfer the file to the computer without the network driver. If you have a disc with the drivers, then just reload that. If not and since you can't connect to the Internet to download the driver, you need a USB flash drive.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Frist you dont need any extra drivers for your Cam, Its plug n play and opens up on your computer as A hard drive.
1. Plug your USB cable in your computer.
2. Now turn on your Cam.
3. Now plug your USB Cable in to your In/out on your cam
4. Look at your cam and set it to "OUT"
5. A new folder should pop up some tims 2 folders. open each folder tell you find you files.
6. now pick the files you wont, right mouse click and pick "Cut" then right mouse click and past to the folder you wont your photos in.
Hope I could Help.
1. Make sure that the USB cable of your MP3 is known working. 2. Connect your MP3 into different USB port of your computer. 3. Connect the MP3 into different computer to see if there's a problem with the computer or with the MP3.
If the MP3 gets detected using another computer, then there's something wrong with your computer. It could be that there's a drive letter conflict or the USB ports could be weak to detect the device.
