Question about Toshiba Tecra 8100 Notebook
Tecra 8100 Freezes shortly after Windows comes up
The 8100 will start normally and work just fine for 2-3 min. then freeze up. If you keep trying to book after the the freeze it will start to freeze sooner and sooner. Letting it sit for a while it will then boot back up and work for the 2-3 min. and then freeze all over again. Thinking it was a cooling problem (as it would freeze up after it became warm) I removed the fan but it works fine on the bench. Not sure where to go.
  • jeffrey_kais Jan 14, 2009
    Thank you so much for your feedback. However, I'm not sure its a SW problem. After the PC is on, frozen, and warmed up (and re-booted a few times) it won't even get into the BIOS (as it appears the CPU is over heated). It definitely seems to be temperature related. If it was SW I would suspect I'd be able to get to the same point of failure each time, consistently, but I don't. When the system is first started I can get 2-3 min. into Win2000; when power has been applied for some time, it can't even get through the BIOS. Additional comments? Thank you again!
  • jeffrey_kais Jan 17, 2009
    As I suspected, it turned out to be a HW issue - not a SW problem. The motherboard supply to the CPU fan no longer put out the correct voltage, thus the fan did not operate - allowing the CPU to over heat and shut down.
    Novelist:
  • 140 Answers
Go into your hard disk utility and defragment your file. When the computer writes to your hard disk over time these files no longer are sequential as they were in the beginning. This is one solution, also you can do a disk recovery using your original disk or by pressing F10 as it boots up. Be sure and do a good check for viruses as well. The symptom you are describing sounds alot like a virus that is slowing your system down more and more. Good luck.
Posted on Jan 14, 2009
  • roberto serbin Jan 14, 2009
    You would not necessarily be able to get to the same point of failur each time. If you are not able to get to the cmos setup screen by pressing F1 as it boots to reset your system defaults then I still would try to run a recovery since it takes more than 2 to 3 minutes to run. If it still shuts down it could be a hardware problem but it just does not sound like to me. God bless.
Screen freezes up
These sets are known to have issues with the digital board. Parts can be bought from www.samsungparts.com The part isn't cheap. when it freezes up does the video stop then after so long the video goes blank then it comes back to normal. Sometimes unplugging them will make them work for a short time but after a few days to a week or so they start acting up again.
Mar 07, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
My Satellite L300 crackles then freezes after a short time - approx 30 mins. The problem seems to be exacerbated by plugging in a USB device, such as mobile broadband dongle. Once it freezes, I can't even...
Sounds like the power adapter/charger module inside the laptop.
Laptops not so easy to trouble shoot as desktops.
Might be a USB short if that makes it worse?
Apr 04, 2010 | Toshiba Tecra M1 PC Laptops
Start menu freezing
This sounds like you may have a virus running up cpu time or a trojan of some sort, try running a virus check Antivir is a good free virus cleaner, also run spybot search and destroy to look for spyware. sometimes viruses attack windows system files to keep you from being able to get rid of them.
Jan 18, 2010 | Dell Inspiron E1505 Notebook
Green light of "hell"
Try reinitializing the set press menu 8970
Oct 13, 2009 | Mitsubishi WS-65615 65" TV
My Toshiba Tecra 8200 Boots as far as Wallpaper and then freezes and nothing will start it Colin.
try booting it in safe mode if it boots restore your pc to some back date where its working fine
Jun 14, 2009 | Toshiba Tecra M1 PC Laptops
After 15 mins it freezes
go msconfig uncheak all start up **** update all windows updates adoe shock player flash ect uncheak advaced ideams on grafics area in prteries under my computer try all that 1st ok use classic mode also help speed
Oct 10, 2008 | Gateway Pentium III , 933 MHz Processor...
Tecra 8100
remove the battery, run it on ac power pack, for five min, then install battery while it's on.
Apr 18, 2008 | Toshiba Tecra 8100 Notebook
Blackberry Keeps Freezing Up
It is not supposed to occur in a Normal Phone. You should try formatting the Phone (Don't forget to make a Back-Up Copy of the Data in your Phone before).
Apr 01, 2008 | RIM BlackBerry Pearl 8100
Toshiba Tecra 8100 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
