Question about Platinum Datacard Magna ID Card Printer
Overlay module not communication with printer
I have datacard magna printer platinum series printer. I keep getting an error that overlay module not communicating with rest of printer. It keeps cycling and turning the topcoat reels, but the card just sits there and does not move into the part where it should be laminated.
  • 36 Answers
You would need to replace the entire lamination assembly, it would not be worth cost for parts or time, buy same model printer used or trade in your current for discount on a Datacard CP80 Plus Printer
TulsaBiz.net for more info
Posted on Mar 19, 2010
  • 39 Answers
The lamination station logic board is at fault. I've had the same problem several times with the Platinum model.
At this point, you may consider investing in a newer printer. The board runs $600-$1000, not including labor
Posted on Aug 19, 2009
It is shadowing yellow when I print
Most likely it's either a dirty printer, or a printer than needs a calibration performed.
Printing color cards is done with a series of passes using a ribbon that has a series of panels - yellow, magenta, cyan, black, and a clear overlay. The card is positioned; a panel is printed; the card is repositioned; another panel is printed; etc.
This color "ghosting" or "shadowing" happens when the card is not positioned properly at the start of one or more of the ribbon-panel print-cycles. This can occur when the card slips on dirty rollers, or there is a sensor or calibration issue.
Both procedures are documented in the user manual, and at the Datacard web-site. I'd perform the recommended cleaning first. If it's been a long time since cleaning, I'd do it more than once.
If that doesn't correct your issue, the next step would be to perform a calibration.
If it is still not performing properly after the above steps, you may need to have the device serviced, as a sensor could be failed or failing.
Mar 17, 2015 | Datacard SP55 Plus Two-Sided Printer
Datacard printer SP75 plus error code error DM-00762 (Duplex Jam)
Open the duplex module cover at the back of the printer (1).
Release any cards stuck in the module (2). Make sure that the duplex
mechanism can move freely in the direction shown
For more help visit cbrtechsolutions
Jun 20, 2013 | Office Equipment & Supplies
Hello. do you have datacard magna drivers for windows 7
Datacard does not make nor do windows 7 drivers exist, the printer is obsolete and end of support from datacard was in 2006, you need to upgrade your printer. Check TulsaBiz.net or Midwestidsolutions.com for more info.
Jul 08, 2011 | Datacard Group ImageCard Platinum S...
Hi. I have a Datacard magna platinun and I need the Vista drivers. could help to get them.
Hi gatr216,
Have exactly the same problem as you and have still not found a solution. How about you did you manage to find the correct driver?
Robert
Sep 21, 2010 | Datacard Group ImageCard Platinum S...
I install the driver from datacard site but no works with the smart drive
Please post more info, Need Driver version and more info about problem. Can you access the printer toolbox?
Oct 05, 2009 | Datacard Group ImageCard Platinum S...
Centering the print on the card (Magna w/ait)
card alignment is adjusted via the smart driver tool panel (edge to edge settings) it is done via software, there is no adjustment possible in the printer.
Aug 30, 2009 | Datacard Group Datacard? Magna Platinum...
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Datacard ID Card printer has scsi port and I have no idea...
It is not a scsi port it is a parallel port, the end that plugs into the printer just uses a smaller parallel connector, the other end will plug into a standard printer port. The cable is common used bu HP and Datacard, We have some used for about $10 Plus shipping www.midwestidsolutions.com
MidWestIdSolutions (DOT) com contact us for ordering
Apr 10, 2009 | Platinum Datacard Magna ID Card Printer
Having a problem with new toner in a HP6L laser printer
If the problem was not there before you replaced the cartridge then I suggest that the toner cartridge is at fault. If you touch the blue drum in the toner cartridge ( under the flap ) with your fingers then that can also cause a smear.
Mar 06, 2009 | Datacard Group Cleaning Card (for Select,...
Platinum Datacard Magna ID Card Printer Logo
188 people viewed this question
Top Platinum Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Platinum Office Equipment and Supply Expert? Answer questions, earn points and help others
