Question about HP OfficeJet 7410 All-In-One InkJet Printer
7410 problem re your suggestion to clean/align:  tried via computer and got error message-also at 7410 I can not get beyond the message to" remove and check "              bobandcarolj
  • 1 more comment
  • bobandcarolj Jan 14, 2009
    message: an unexpected error has occurred (1100) ........ from I MAC. 7410 just keeps the warning message "remove and check color cartridge"
  • stkeric Feb 12, 2009
    I have the same problem, only with the black ink.
  • Dan rogers
    Dan rogers May 11, 2010
    what is the error message that displays when you try to clean\align
    Master:
  • 413 Answers
Try visiting this site and cleaning as it recommends and let me know if it resolved the problem. Everyhthing is pointing to ink cartrige malfunction. I am looking for some other solutions, like i said try this and let me know what happens
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&jumpid=ot_recdoc/bpu00657/en_us/buu02180/loc:1&custom_solutionid=rd_bpu00657&lc=en&dlc=en&cc=us&product=391194
Posted on Jan 14, 2009
Call service
You may have gotten an incorrect message and removing and replacing the drum is a step in right direction. But if you continue to get the same message I am afraid you will have to replace the drum - they do wear out.
Aug 19, 2015 | Kyocera FS Office Equipment & Supplies
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
Printer is showing an error message call service
Take out and reinstall drum unit. You will need to remove toner assy and waste ink bottle to do this. 7410 is the error, 98681 is the page count.
Nov 16, 2010 | Kyocera FS-4000DN Laser Printer
Error message is remove and check color cartridge. tried to clean nozzles and checked that it was in securely.
clean the printer cartridge nozzle and carraige assembly with the spirit or clean soft cloth. also on the printer software there should be a maintenance menu , clean teh printer and do the mainetancne form there
Sep 28, 2010 | HP OfficeJet 7410 All-In-One InkJet...
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
C6180 clear carriage jam
Change ur categer and clean ur inside the printer,and delete old documents.
Jul 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP 7410 Printer Error
Is the printer highlighted? Is it set as a default printer?
Oct 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
