Question about HP Color LaserJet 2600n Printer
Cyan error 50.21
My red quit working and I cleaned the scanner with cotton. After assembly, the cyan error 50.21 appears on the printer screen. I replace the cathridge but the error won't go away and the printer won't work. What did I do wrong.
    New Friend:
QUESTION: i have a major problem! someone gave me a HP INVENT MODEL NUMBER SDGOA0703, it is still a good looking printer, memory cards go in front. but here is the pickle- where can i find an ink cartridge access door, i cannot move past a screen saying "close ink cartridge access door" I really want to fix it up and make it work. hopefully with some TLC it will work out, can anyone help me find e to even look for the access door and the tray that catches the photo when it comes out from printing? please an thanks, ashley
Posted on Apr 19, 2013
    Genius:
  • 1,605 Answers
Most likely the cotton you used is the problem.
take out the ink cartridge and see of there are any cotton stuck to the ink cartridge and the cradle.
use a coffee filter with some alcohol and clean the cradle and the ink cartridge contact. (lightly).
Posted on Jan 14, 2009
What is the solution to 59.51 error on HP 500 color LaserJet printer.
59 error refers to a Printer motor Error.
59.51 however should not appear on screen.
59.5 is a "Print Cartriddge motor Startup error". The last character should be a letter for which Toner (ie. C, M, Y or K). However I would suggest that the 1 would be the Black motor (seeing as it is the top one). Considering you have replaced the DC controller recently I would say the most likely cause is you have either misconnected or not connected a cable. recheck all your DC controller connections and pay particular attention to connectors J1013 (Cyan Motor), J1031 (Magenta Motor), J1032 (Yellow Motor) and J1033 (Black Motor).
OR
1. Check the cyan cartridge for broken pieces and make sure the drum spins. if so, replace the cyan cartridge
2. Check that connections on the cyan print-cartridge drive motor and on the driver PCA are seated correctly.
3. Replace the cyan print-cartridge drive motor.
4.If error persists, Replace the driver PCA.
5. Replace the main drive assembly.
Dec 06, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Getting error message...the following cartridges red blue yellow appear to be missing or damaged. I removed the red and blue cartridge. There was no yellow,cartridge. The only cartridge I have in th
Hi. Most ink cartridges are cyan magenta yellow and black. You do have to have all cartridge installed for it to work. If it's been sitting for a while ink dries and can cause all kinds of little problems. The ink cartridges have little contacts on them you might have to clean these with a cotton swab and alcohol. But if the ink has dried in the print head you have to clean all the little ink ports on the head.
Feb 10, 2015 | HP Office Equipment & Supplies
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Says the cyan ink cartraige is empy but it is new, replaced it with another new one and still says its empty
remove all cartridges and close the lid. Wait for "ink cartridges missing..." error to appear then install all cartridges and close the lid. If the error persists, remove all cartridges then clean the cyan chip and corresponding contacts in the printer with damp cotton bud. Dry well (with dry c/bud) then fit cartridges back in. If still no good, contact HP.
hope this helps
LC1000
www.inkbank.com.au
Dec 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
Please what can I do to work the machine that says fatal error 133;
133 relates to the cyan LED sensor, infact most likey it is the actual Cyan Image drum.
make suer the LED above the Cyan drum is clean, and freely mounted in the spring assembly.
remove and re instal the image drum..
if that does not work, most likely u need a new image drum,Cyan..i bet it is low and due soon for replacement...
good luck
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
I am having color problems with cyan and magenta with my i9900 printer. I need to understand how Cyan, Photo Cyan, Magenta and Photo Magenta affect the other colors? I know Cyan and Yellow make Green and...
hi!!
try to perform maintenance of your printer
try to open it removed the cartridge
use a screw driver and then clean up the nozzle
use alcohol and cotton buds dry it well then
placed it back again!!!
Nov 10, 2008 | Cannon Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Epson stylus cx5400
Please help....My scanner only shows a large corner portion of the copy. The menu reads ERROR
...no color CYAN etc etc I have contacted many technitions....None have helped The last person Claimed it had to do with low ink....It doesn't make scence. Isn't the scanner separate from the printing components?The printer is in excellant condition...but I was told to dump it and get another I do hope you can HELP....I am 83 yrs young and I have a budget problem....Many Thanks Phyllis
Jul 27, 2008 | Epson Stylus CX5400 All-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
225 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
