Copies are blank
Paper comes out blank
    Guru:
  • 829 Answers
Hi,Which printer do you have
Posted on Jan 14, 2009
What are the commands to initialize scanning lamp or unit or what unit or part is faulty due to which not copying instead giving blank paper.
Make sure the document you are trying to copy is face down on the glass. This and more should be explained in the owners manual.
Feb 27, 2016 | Office Equipment & Supplies
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Paper tray light is on (the small copier on front). Copies come out blank. Just before this happen I tried to copy cardstock, it went through, the second time it would not. Now copies come out blank. New...
Check and clear any dust or peice of paper on the sensor. Also power off the printer and power on to clear the buffer memory may resolve your problem.
Revert back for more assistance.
Jan 29, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Second blank page comes out after copies
check paper size setting and paper pickup
Jun 27, 2009 | Canon PC1061 Copier
We have a Minolta DI250 and when we copy a document comes ot blank in the middle of the paper. Does anybody knows what could be the problem?
Blank in middle could be lack of toner or developer in the developer unit. Also bad charge or transfer coronas. Is paper
wrinkled? You might make a copy and stop the copier before thapaer goes into the fuser, and see what kind of copy on the paper. If complete problem is in the fuser such as warped rollers, etc.....
Aug 28, 2008 | Minolta Office Equipment & Supplies
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
156 people viewed this question
jasbo
jasbo
