Question about Home
Water not hot on my eletric shower
Water isnt as hot as it was. turn the temp up and the water slows down it gets hot but the water comes out to slow to have a shower
Replace electric heating elements, probably the bottom one
Posted on Jan 18, 2009
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
I have powerstar model # 45557701- what causes the cracking noises when water is heating? what will make the unit slow to start to heat? how can i change the heating units?
The crackling noises is just from air in the water and should be of no concern. If you are having a problem of heating up the water with the unit it is most likely do to water moving too fast through the lines. Ideally, there should be a shutoff valve installed on both sides of your heater (makes for easy removal if it needs to be serviced). But if you turn off the valve about 1/4 to 1/2 way on the one on the "in" side of the heater (where the cold water enters) then you will slow down the water going through the heater and this will give the water a better chance to heat up. This should alleviate the heating problems you are having. If you do have a shutoff valve on the cold (in) side of the heater, shut it off about 1/4 to 1/2 way and then go to your shower and turn the hot on all the way (no cold). Wait for the water to warm and test the water by hand to see if it is the temp you want. If it is still not warm enough, turn the hot on the shower DOWN just a little. This will actually make the water hotter. I know this doesnt seem right but it will. On the other hand, if the water coming out with the hot water fully turned on is too hot, then just turn on a little cold water at a time until the water is the temp you want. Remember, always give the water plenty of time to get from the heater to the shower before you decideof its the right temp. Ideally, you should be able to turn the hot water on all the way and get the hot temp that you want and if you want to cool it down, just turn the cold on just a little bit until it is where you want. I'm fairly sure the problems you are having are due to the water going too fast through the unit and once you adjust that and understand better how these tankless heaters work, you wont have any more trouble. They are difficult to get used to after using conventional water heaters and the manufacturers arent very good about giving you these hints so they will work properly. You will need a professional to uninstall and hopefully this will work and you want have to. But if you do, it requires shutting off the water to the unit. Shutting off the pwer to the unit. Unattaching the water lines to the unit and then unattaching the electric lines from the junction box or wherever they are attached. The heater then can be removed from the wall by unscrewing the screws from the hangers which hold it to the wall.
Feb 21, 2011 | Bosch PowerStar AE115 Tankless Water...
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Shower faucet does not switch to hot.
This has happened to me in the past and had exactly the same symptoms but with a different valve. Before trying the below, it may make sense to be 100% sure that hot water is definitely getting to the valve .. can you get access to touch the hot feed pipe to make sure that it is in fact the valve at fault.
The following could be the issue:
1. The shower valve has a bit of dirt or gunk in it and is unable to allow the hot water through. It can happen with a very small amnount of dirt and is a real pain as it requires disassemble of the entire valve assembly.
2. The valve has failed and needs to be replaced - This was the solution to mine and was also significant in terms of effort.
Hope this helps, if so please leave feedback, if not let me know and I'll try and help some more!
Feb 02, 2010 | Delta T13420 Chrome Classic Single Handle...
When the water is turned to hot, it slows down and stops. Plenty of cold water, though.Valve is less than 3 years old.
This model of shower control is a "balanced flow system." This means that water pressure from both sides of the control is equalized by the control.
There is likely something restricting the flow of hot water into the control.
You might try this......
Turn off the water suppling the shower (turn off the water main if nessacary)
Remove the cartriage from the control
remove any visable debris
briefly turn the water on (just a second at the the most) *** make sure the curtain or door is closed first as there will be alot of water coming out of the control itself... Be prepared to clean up some water
reinstall the cartriage
if this does not solve the problem you might consider replacing the cartriage
you might also find that Moen has more helpful info their phone # is 800-289-6636 they have been very helpful the few times i've called
Oct 28, 2009 | Moen & Posi-Temp Single Handle Shower Or...
I have a new moen single handle shower faucet that is only giving one temp of water (cold). Only if I have it on very slow will I feel hot water. Any idea how to fix
Did the hot water shut off get turned back on fully after the change? Is the hot water line kinked under the sink? Is the hot water shut off valve working?
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Inadequate hot water supply
Tankless Water heater tempature is regulated by the rate(amount) of water flowing through the device. To get warmer water for the hot side, slow down the elbo stop leading into the device. Since it is a shower,and you did not say one handle or two.You will have to slow the rate for the cold as well , if one, unless it is an ajustable valve. The drawbacks to the tankless heaters.
Jan 18, 2009 | Rheem Tankless Hot Water Heater...
Home Logo
119 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
