Question about Namco Ace Combat 6 Flight Bundle: Xbox 360
How to connect the flight stick to the Xbox 360?
The joystick has a grey wire with a round end- how do I connect that to my 360??
  • sneakytree Feb 11, 2009
    i also have that connection but i do not have an extra wire to connect the cable to usb. is there a way i can get one of these?
  • 40 Answers
There are no slots on the 360 for that kind of connection. You should have another smaller wire which this plugs into, and on the other end is a USB.
Posted on Jan 16, 2009
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
Jun 12, 2011 | Saitek X52 Flight Control System
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
Wired Guitar for X Box 360 from Rockband, no connection?
Dude your probably thinking about the Break away cord Or the cord that pulls out before the USB cord for your xbox 360, the guitar comes with 2 parts The guitar with a cord and the breakaway extender the Extender plugs into the front of the Xbox in a little Usb slot :)
May 31, 2009 | MTV Games Rock Band Bundle for Xbox 360
Ace combat 6 flight stick controller
order a new controller or replacement parts of ebay....
Dec 24, 2008 | Namco Ace Combat 6 Flight Bundle: Xbox 360
Getting two joysticks to work on one game
i don't think that xbox arcade xbox 360 are they compatable with it
Nov 29, 2008 | Microsoft Xbox 360 Console
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Right joystick
I don't personally know of anywhere that will replace the stick. If it truly is broken as you say, you will need to purchase another one. After all, it is broken.
Nov 11, 2008 | Microsoft MS Xbox 360 Common Controller...
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
Namco Ace Combat 6 Flight Bundle: Xbox 360 Logo
624 people viewed this question
Top Namco Video Game Consoles & Games Experts
Jim Goldsmith
Jim Goldsmith
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
