Question about Microwave Ovens
HV CAPACITOR FOR SHARP MICROWAVE
I CAN NOT FIND AN HV CAPACITOR 0.37MF 2400 MVAC FOR MY SHARP R9H20 MIVROWAVE OVEN .
WHERE TO GET ONE?
THANK YOU
DABADEBO
  • mobzayed Jan 14, 2009
    THANKS SHADE TEK CPC FARNELL DOES HAVE HV CAP THE MAX THEY GOT 500V. HV CAP SHOULD STAND 4000-5000V.
    THANK YOU
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Sharp may not sell you this spare part as it is a high voltage saftey part. You would have to take the oven to a Sharp dealer to have it fitted. However, CPC Farnell in the UK may supply, but be careful.
Posted on Jan 14, 2009
Where is the fuse located on the sharp r-1875 microwave
you have to take off the external housing and you will see a glass fuse near the power source.
Jul 19, 2011 | Sharp R-1874 Convection/Microwave Oven
My sharp r-209hk suddenly stopped heating. the motor makes more noise and food won't heat
If there is no heat it is the Magnetron. The other 1 from the 9/10 is the HV (High Voltage) Diode that connects to the HV Capacitor.This is the cheaper fix of the two with them being usually under $12. The Magnetron is rather high ranging from approx. $50 and up.Have the blown parts replaced.Thanks
Jan 24, 2011 | Sharp R-209HK Microwave Oven
Microwave owen SHARP Model R9H20 Digital START button is not working. Need Workshop address in Dammam or Al-Khobar, Saudi Arabia including phone numbers to fix the problem.
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
zaffarlone@yahoo.com
Zaffar Iqbal
Dec 18, 2010 | Sharp Microwave Ovens
Why would the high voltage capacitor go bad?
Hi and welcome to FixYa. I am Kelly. High voltage capacitors can and do fail when a microwave is used for long periods of operation, when the unit is operated with no internal load and sometimes for no reason at all other than the capacitor had an internal failure such as corrosion or a break down of the metal strips inside of it where the strips can make contact with the the case. I have been working on microwaves since the 70's and often there is no apparent reason for the failure of the HV cap.. They just sometimes fail.
However...... there is also a power diode in the microwave that is connected directly to one terminal of the HV Cap. If the power diode has failed it can cause subsequent failure of the HV Cap. The Sharp Power diodes can be found here: http://www.repairclinic.com/Sharp-Microwave-Parts?s=t-FH-DZA119WRKZ-%3d%3db113a6c41
You use and ohm meter on resistance to check the diode AFTER removing the terminal of the diode from the capacitor. NOTE: the capacitor must be shorted across the terminals at least 3 times with a screwdriver while holding the handle only to prevent a horrible shock.
Once the diode terminal is disconnected from the HV Cap read resistance in BOTH directions by reversing the test leads on the terminals of the diode. One direction will read resistance and the other direction it will read open / infinity. Any other reading is a failed diode.
You check the capacitor using an analog (scaled vs digital display) ohm meter on R X 1,000 or R X 10,000 and watch for a jump on the meter just as you touch the terminals EACH time you reverse the leads. No jump or... steady resistance = bad Cap.
Sharp Capacitors can be found here:
http://www.repairclinic.com/Sharp-Microwave-Parts?s=t-FH-DZA119WRKZ-%3d%3db113a6c12
Just note that either a CAP or Diode failure can cause the main fuse to blow at the end of the power cord in the fuse holder.
Fuses are normally either 15 or 20 A Slo-Blo fuses and can be found here:
http://www.repairclinic.com/Sharp-Microwave-Parts?s=t-FH-DZA119WRKZ-%3d%3db113a6c44
Thanks for choosing FixYa
Kelly
Sep 29, 2010 | Sharp Dial Microwave R-21LCF Microwave...
Hi, I have a SHARP Microwave Model R398F. Its less than a year old. The display and timer work fine but does not heat up. Can you please let me know what the problem could be. Thanks Js
If the operation is otherwise normal with the exception of heating food, common causes include; (to diagnose requires discharging of the HV capacitor) if you are inexperienced with working with HV I suggest seeking professional help.
Open thermal protectors or thermal fuses.
Open HV Diode.
Open HV capacitor
Open magnetron filament
Open winding in HV transformer
Defective HV relay
Shorted HV diode
Short or other fault in the magnetron
Short in certain portions of the HV wiring
Replacement Magnetrons (the most likely cause if not charring or defective components are found when troublshooting the small parts, can typically be had for around $45.00 just do a web search for your model number.
Good Luck
Sep 07, 2010 | Sharp Microwave Ovens
My sharp mivrowave model # r-1875 shuts off every 59 seconds how do i fix it
Therre is a timer that has to be replaced by a qualified technician, either A & E appliance repair or Sears Home Central. I had the same problem with that model Sharp. Good luck.
Sep 18, 2009 | Sharp Microwave Ovens
I have a Dacor microwave DMO24 oven which i think is manufactured by Sharp. when the cook function is started it will hum/buzz for about 1 second and then blow a fuse. from the sound, and it's...
It is indeed made by Sharp.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
OR, we have the service / repair manual for this model and have uploaded it to our site here to help you.
The parts list is here.
You can order Dacor parts
here.
If you prefer to order the original Sharp parts (which are usually considerably less) look for the part number on a tag on the transformer or capacitor (whichever is bad).
The part number for the capacitor will be similar to RC-QZBOl8MREO and the transformer number will be similar to RTRN-BO59MREO. Again, these numbers are examples to show Sharp's number format.
You can order Sharp parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 18, 2009 | Sharp R-1480 Microwave Oven
SHARP MICROWAVE R9H20 STOCKED FOR LONG
if the problem is tempermental then is sounde like you may have a failing interlock switch. this is a series of switches that are activated then the door closes. there are normally 3 and you would be looking for/ replacing the middle the Primary interlock...
Hope that helps
Jan 11, 2009 | Sharp R-510HW Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
