How can i unprotect my flash memory?
Hi, i got a kingstone's flash memory and it's protected so i can't add anything to it or delete anything on it so how can i remove the protection??
  • 298 Answers
Itty-tiny switch located in a slot on the side. Use a paperclip and slide it or opposite position
Or use HP USB Format tool from Extreme Tech
http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Posted on Jan 17, 2009
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
I have a 126gb Kingston pen drive which states it is write protected when I wish to delete files. How do I unprotect the drive?
try to scan your pen drive in updated virus scanner then try to delete files .because infected files are hard to delete.
May 16, 2011 | Kingston (S40J107) Hard Drive
How can i unprotect my kingston data traveler 4gb usb flash drive? i cannot save data and when i reformat it it said it is in write protect.
if there is a switch on the side that changes colour from white to red that is the write protect, you may also have reached the capacity of writes to the card and this is also why it is saying write protected as it cant write to it anymore. These flash drives do have a high amount of writes for its life, but if you have been using it as a memory booster for vista or win 7 then those read and writes will soon mount up.
Mar 30, 2011 | Kingston Digital 4GB DATATRAVELER C10...
I can't format,add or delete files form my flash it's Kingston 16GB Data Traveler G2
kingston is not good USB.....it is easy to be write protected.......difficult to solve
Oct 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Hi, i have a problem with my card. It says that the memory card is "protected". I am unable to take any photos or delete any photos. I am unsure of how it became "protected" Can you tell me how to...
On the side of your card, there's a very small notch/switch that moves up and down. It can be bumped into the "lock" position which prevents writing to the disk. You need to switch this little tab back to the other position. This is a standard feature on most/all flash memory cards.
Mar 03, 2010 | PNY 2GB microSD Memory Card
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
REMOVING WRITE PROTECTION FROM MY USB 2 FLASH DRIVE
Hi, I am having problem copying or deleting from my Kingston Flash USB 4 flash drive. suddenly I could not delete or even copy anything into the drive. It keeps on indicating your disk is write protected. I have not secured the disk with a password, even then I have this problem....
How can i recover in this problem.
Jul 04, 2008 | iLO (2 GB) MP3 Player
How to unprotect the memory card
i am having lg 6600 it is showing protected how to un proected it?
Nov 18, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
Computers & Internet Logo
483 people viewed this question
David Payne
David Payne
