Question about Canon DR 3080C Path-Through Scanner
Scanner can't scan multiple papers by itself.
Normally with a scanner you can load multiple papers and it will scan them one at a time. With mine, I have to load them in one at a time or else the scanner will take a few of them at one time and obviously just scan the page on the bottom of those papers. What do I have to fix in order for it to only catch one paper at a time?
  • 490 Answers
Ensure the rollers are clean. Clean with with a damp cloth or with IsoPropyl Alcohol (IPA Industrial Grade). Dont use solvents. Check if the papers are sticky. Sometimes stapled documets are held together at the point where is it was stapled. The small 'depression' is enough to hold two papers together.
S. Mohan, Chennai, India
Posted on Feb 24, 2009
Epson gts50 wont stop scanning until paper jam occurs
I just started having the same issue. However, I don't think the problems was understood. You can one sheet of paper; that's all you need to scan. The scanner will not stop until it has cycled through 8 scans and which point it will then prompt that a e1: Paper Jam has occured. You can hit ok and still safe the document, but it is annoying have to go through the cycles or hit cancel to stop the cycling (at which point you can then still save the scan). I believe Alan and I are both looking for a solution to resolve the issue.
Mine started after a serious paper jam. I am in a rather unique situation as I have to requested elevated priveledges to down load/update any drivers. So personnally I am trying to find a way to work around the issue.
Thoughts would be greatly appreciated.
Jan 13, 2014 | Epson Office Equipment & Supplies
Black line on scans with neat receipts mobile scanner
Multiple lines appeared in every scan right after scanning a document from a credit card company that had those nasty adhesive strips used to attach credit cards.
First, I scanned multiple full pages to see if the problem would clear itself. After about 6 pages, I was able to identify the specific areas where the lines occurred on a document.
Next, I sprayed a tiny bit of glass cleaner (I used Sparkle glass cleaner, but I suspect any brand would work) onto an 8.5x11 sheet of plain paper in the area where the black lines appeared. NOTE: DO NOT SOAK THE PAPER, just get it damp.
Finally, I ran the dampened paper through the scanner. After each run, I would compare the result to the prior scan. As each streak was removed, I used a different piece of paper wetting only to address the remaining streaks.
After only a few runs, the streaks were gone (in my case).
Hope this helps!
May 14, 2012 | NEAT Receipts Mobile Scanner
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
I want to know how to use the scanner - we have lost instructions
Instructions
    • 1 Determine if the scanner has flatbed only or ADF (automatic document feeder). Scanners with have a flat glass section for scanning, but they may or may not have an ADF. Determine if your scanner has one of those so you can scan one sheet or multiple sheets at a time.
    • 2 Place paper in respective slot. Insert the paper into either the ADF, or place on the flatbed for scanning use. Make sure the glass is relatively clean. If you're using the paper feeder, make sure the pages do not have staples or paper clips still attached.
    • 3 Press the "Scan" button or use an application on the computer that can interface with your scanner. Use this to grab the image of the documents or pictures you desire to be digitized.
    • 4 Save scanned item as you want it. Store the now digitized image to whatever format you desire (whether it is PDF, JPG or other). Keep track of where your storage location is so you may retrieve the data soon.
    • 5 Retrieve it. Remove your papers, and browse to your digitized documents.
This is picture guide visit this site.
http://www.dummies.com/how-to/content/how-to-use-a-scanner.html
May 19, 2011 | Computers & Internet
Am unable to use the feeder tray - it keeps saying paper jam. There is no jam -- something seems to be blocking the mobility of the paper. I have it on "office" use and the regular scan works one...
Click on the link below and download the User guide which will help you solve the paper jam problem.
User Manual
The above link has complete information for your Epson Scanner.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 13, 2010 | Epson Perfection 4490 Office Flatbed...
How do I add multiple pages to one scanned doucment?
Open your Adobe Acrobat (e.g., 9.0 Pro), load your pages into the document feeder (fewer than 30 at a time), then ask Adobe Acrobat to create PDF from scanner (File/Create PDF/From Scanner). Canon MP530 as the scanner and click OK. Works like a charm!
Jul 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
The scanner wont scan, everytime i add papers it will act like its about to scan but then says there is a jam.
These scanners have multiple sensors, that can check if there is a double feed or paper jam. May be one of them is faulty or a small piece of paper is stuck there. Remove/clean this and the scanner will be fine.
Jan 02, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Misfeed when scanning documents
What you want to try it take a blank paper and on the middle of the page on front put a small ammount of rubbing alcohol on it, then enter the paper into the scanner and hold it so you jam it as it feeds. Then look at the area you placed the alcohol for the presence of some dirt, a blackish smear will normally appear on the paper, Do that 4 or 5 times and that will clean the wheels well. If it helps, then most likely you have just textured the rollers for a short period of time and they should be replaced. But the reason why you want to try that is to be sure the problem is slipping by the roller texture and not the roller drives, ( a clutch or motor). But since it sounds like you give your scanner a workout, the rollers are most likely the problem. Replace all the feed rollers and also look for a pad that presses against the feed roller. Depending on the type of scanner there will be either one roller that barely moves or a rubber pad that is called a skid or ****** pad, what they do is limit or ****** the feed of multiple sheets of paper. I would recommend replacing that , pad or stationary roller, it is important in feeding.
Oct 17, 2008 | Sharp AR-M450N Copier
Canon 4010C
hmmm i thin u r missing some setting in ur driver.
else reinstall the driver
Jun 16, 2008 | Office Equipment & Supplies
Canon DR 3080C Path-Through Scanner Logo
100 people viewed this question
old marine
old marine
