Question about LaCie (300951U) 500 GB Hard Drive
Unusable space I have a 500 gb drive, but can only use 465 gb. Where is the reat of the space and how do I recover it. I am using a Mac G4. Thanks, j4409
    Genius:
  • 2,985 Answers
This is anomaly of nomenclature. A megabyte for example, is thought of and in printed description such as this as 1000 bytes It is in fact 1024 bytes- do the sum you have exactly the right number of byres.
Posted on Jun 14, 2007
My G4 see the drive but it thinks it is a 120 GB drive when it is really a 500 GB drive. How do I get the G4 to recognize the 500 GB drive as a 500 GB drive and not as a 120 GB drive? Jim
The drive may not be formatted to correctly to work with a Mac as most are pre-formatted for PC use.
Use the Disc Utility on your Mac application to format your drive as Mac OS Extended.
Use the Zero out data option for best results, this may take an hour or two. It's in he Erase section.
May 27, 2011 | Apple Power Mac G4 Desktop
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
Hi.
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
Hi, I bought the little disk (500 gb) and took it to a friend en he has a mac (i've windows) he punt some fileson teh disk after het installed it (for the first time) Now mij computer doesn't find the disk...
Mac uses diffirent file-system than windows.
Are the files on the disk important?
If not, you can do following (a complete formatting of the disk)
1. Press Win+R
2. Write diskmgmt.msc and press enter
3. Select your removable disk (if you don't know the name of the disk select a removable drive thats capasity is almost 500gb
4. Right click the drive and select remove partition
5.when deleted Right click free space and select create a new partition.
6.follow the instructions and you're done.
Mar 20, 2010 | LaCie (300951U) 500 GB Hard Drive
Not enough space to back up?
sure..the back ups are compressed files, usually, and though it appears to be a small file, the external drive will allocate the space that it needs. Mac's won't put a file anywhere that there is not enough room. PC's will slice it and spread it around, of course.
I recommend you off load some of those backups to DVD's and keep them for a month or so.
Or get more disk space.
Dec 05, 2009 | Western Digital My Book Essential Edition...
Help with MyBook 500 GB- it makes a clicking sound and does not appear on my MAC desktop.
You have a bad hard drive. The clicking is a giveaway that something is wrong. Replace the hard drive.
I hope you had backed up your data, otherwise it may be gone. It's very expensive to have data recovered from a bad drive.....hundreds, sometimes thousands of dollars.
Jul 09, 2009 | Western Digital My Book Essential Edition...
Hard drive won't mount on my mac bookpro
say goodbye to them, you might not sleep today but you'll forget about it
when noise happens the needle isnt reading the disk, unless you pay $500 to a data lab to recover it "if they can" usualy they cant
Mar 12, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
221 GB Free on MyBook - Error states not enough space for backup
Is the drive formatted as FAT32?
If so, and your backup is more than 4GB, it will not be able to write the file to the drive.
Open a Command Prompt (Start | Run | CMD) and at the prompt type:
CONVERT V: /FS:NTFS /X
Where V: is the drive letter of your My Book.
That will convert it to NTFS and it will be able to handle files larger than 4GB.
Apr 28, 2008 | Western Digital My Book Essential Edition...
Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Nov 08, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie (300951U) 500 GB Hard Drive Logo
88 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
