Question about HP Pavilion dv4000 Notebook
HP Wireless Assistant
Hello, I'm hoping someone can help me. I am using a HP Presairo F500 Laptop, model: GF596UAR#ABA. I've had no problems/issues using the integrated wireless feature until yesterday, when for no apparent reason I lost all wireless connectivity. I cannot even launch the HP Wireless Assistant to troubleshoot. Any ideas would be appreciated. I think it is bigger than that...I lost wireless assistant then discovered that I also lost the files for Windows Defender and Spyware Doctor. The laptop does not recognize the USB ports. I think this is an attack. But, I am not certain..
  • 520 Answers
Mmm a mystery...
are you part of a network or adhoc are others able to connect to ur pc.
you could download the drivers and reinstall them and if spyware doctor and win defender are registered you can always retrieve them.
after doing this I would consider installing norton antivirus or norton 360..I use norton 360 on all my machines.
Posted on Jan 15, 2009
Power problem power is not on
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, your compaq f500 power adapter is probably faulty and needs replacement.Hope this helps.
Jan 30, 2013 | Compaq Presario F500 Series Laptop...
Hi there I have a compaq presairo F500 and the wireless internet switch at the front of the computer is not working, its not picking up any wireless connections. the light stays amber, its not picking up...
Some HP computers I've seen recently, and Compaq is owned by HP, had an issue where the wireless card was not soldered down correctly. Over time the general wear and tear laptop computers face caused this wireless card to slowly work its way out, disconnecting it from the computer.
I would contact Compaq, or Best buy (depending where you bought it) and check if your warranty is still good. If it is, they should fix this for you. Otherwise your next best option is to buy a USB wifi adapter from www.newegg.com, or www.amazon.com. It is unfortunately not possible for you to re-solder the wireless card in unless if you are very comfortable with working with delicate electronics.
Mar 01, 2011 | HP Compaq Presario F500 F700 and G6000...
Hp compaq f500 gf596uar windows 7 - my wireless is not working...i try with other os buth nothing. Sorry for my english
Hello, Assuming there are wireless networks in range. I would suggest the wireless network on the Laptop has been switched OFF. Look on the front of the laptop for the wireless switch and make sure it is set to the ON position. Once on an ICON on the sttus bar should come on for you to search and log on to the available wireless networks in range.
I hope this solves your problem you are eperiencing.
See photos for location of the switch.
Regards,
Feb 04, 2011 | HP Pavilion dv6000z Notebook
Hp wireless assistant please give me a fix for the orange/blue light issue
Ok. THIS IS THE FIRST SIGN YOUR LAPTOP IS GOING TO FAIL. I have this exact same laptop and the exact same issue except that mine has already died. Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Dec 28, 2009 | HP Compaq Presario F500 F700 and G6000...
WiFi adapter not workin can you help!!!!! Please model number GF596UA#ABA
Ok. THIS IS ONE OF HTE ISSUES OF A LAPTOP THAT IS GOING TO FAIL. I have this exact same laptop and the exact same issue. Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
Oct 15, 2009 | HP Compaq Presario F500 F700 and G6000...
HP Wireless assistant not working, light staying orange
Window Vista- Go To Control Panel, then go to Mobile PC, then Window Mobility Center, then go to the top right of the mobility center and click on Turn Wireless On
May 27, 2009 | Microsoft Windows Vista Home Premium...
After buying the laptop in april 2007 my compaq presario F500 the wireless connection has disappeared and the light is contantly orange which ever way i moved the button to turn on the wireless.
Hello Handbag.
The issue which you are facing is a known issue. This is common in F500 series notebooks.
You can get it repired for free of cost by contacting HP technical support, even if the notebook is out of warranty.
All you have to do is refer the below link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01480071&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
And check if you product is listed here. Then contact HP support by chat or email., then you can get the notebook repaired.
Sep 24, 2008 | Compaq Computers & Internet
Wireless assistant
here is the link... download your Wireless assistant install it on your computer...
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46858-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3360261
Sep 05, 2008 | Compaq Presario 700 470024-192 Notebook
I just had the same problem with my wife's HP Pavillion dv6000 laptop.
It was working fine, then just stopped recognizing the wireless card. My daughter had been using it, so I was in doubt as to what had/hadn't been done to it software-wise (virus?). So I ran the complete recover to restore everything to the state when it was new.
Still can't recognize the wireless. The indicator light stays orange no matter which position the switch is in.
So I google "HP dv6000" looking for a manual, and the FIRST thing I find is a Recall notice http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277 Yeah, I know, they're covering their butts by calling it a
"Limited Warranty Service Enhancement" but they basically know that these machines were defective from the date of manufacure. They told me that my machine didn't qualify for the free service because it was 9 months past the warranty extension and tried to get me to shell out $250 for a new mother board.
Maybe I'll try the external wireless card solution, but it sounds like the MB will probably go bad next. I've owned a bunch of HP computers (have four of them working in the house right now) but I'll probably be looking at Dell next time around.
Jul 27, 2008 | HP Pavilion dv6000z Notebook
Presairo f504eu will not connect to internet via wireless .will not switch on have reset pc updated drivers wirless assistant will not open changed broadcom card for new still not working HELP
This is a problem with most Compaq Laptops in the F500 series, and as such, HP has extended their warranty on all affected models, so you should contact them and they should repair it free of charge with 1-2 weeks. If you bought it from a high-street retailer, such as PC World, then you should take it to them and they should be aware of the situation and repair it for you.
Apr 19, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
310 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
