Question about HP OfficeJet V40 All-In-One InkJet Printer
Black paper when I try to print the paper is coming black. How can I solve this problem Iput white papers and I get blacks
  • Anonymous Feb 15, 2009
    When I try to scan the picture comes through all black; same as when I fax someone, they call me to tell me that my fax is all black & they cannot read text.
    Guru:
  • HP Master
  • 829 Answers
Switch to a higher print mode. Follow the steps below to switch to a higher print mode.
  1. In the program you are printing from, click File and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, click the next high-quality setting. If the current setting is Draft, click Normal. If the current setting is Normal, click Best.
Posted on Jan 14, 2009
Type of paper Xerox DocuColour 1632 can print on
DocuColor 1632 can print on:
Plain paper (A4/210 x 297mm LEF):
? Black and white: 32 ppm; colour: 16 ppm
Transparency:
? Black and white: 13 ppm; colour: 7 ppm
Heavyweight 1 (106 to 169gsm):
? Black and white: 13 ppm; colour: 8 ppm
Heavyweight 2 (170 to 220gsm):
? Black and white: 8 ppm; colour: 8 ppm
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 01, 2011 | Office Equipment & Supplies
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Black cardstock
There is no white ink in the printer. White needs to come from the paper.
The inks in your printer can only make your paper DARKER, and you can't get any darker than black.
Oct 08, 2008 | Lexmark P6250 All-In-One InkJet Photo...
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
PRINTING ON BLACK PAPER
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
The black and white does work
Your printer canno read the black cartridge because it was not sat down in it's proper position. Do not be afraud to click it into place, consult your manual on proper cartridge refilling, and positioning. If it is not quite in and you try to print, no black will come out of course. Once right in place try and print again.
Mar 26, 2007 | Canon BubbleJet i560 InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
