Question about Royal VF1012mx Shredder
Paper Shredder will not shut off when in auto mode
My shredder powers up, works when I have it in auto and put in the first papers. When those paper complete the shredder does not turn off. I can turn if off manually, then put it back in auto and it does the same thing. it does work in reverse. Is there something I can check like a sensor to make the auto function work again? --lwp--
  • Anonymous Mar 19, 2014
    i have a vc880c from vericash, it's supposed to be new. i turned it on and the light is ok but when i put the paper makes a little louder noise but doesn't work
  • Anonymous Mar 22, 2014
    I shedded 3 pieces of paper and the shedder did not shut off while it was in auto. I then put it in reverse and it would not go. the motor then started to smoke.
Where do i by a motor for my shredder to replease it
Posted on Sep 06, 2009
  • 883 Answers
If you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Posted on Jun 14, 2007
Can not get paper to shred
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 26, 2013 | Omnitech Office Equipment & Supplies
No power. Seems to be overloaded
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
Wont turn on
Oct 01, 2013 | Cross Infoguard Shredder SX102M
I jammed it with too much paper
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
The shredder is totally inoperable
Sep 17, 2013 | HSM Office Equipment & Supplies
Red light and green light on but motor will not come on
Sep 13, 2013 | Fellowes PS60-2 Shredder
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Sep 04, 2013 | Quartet gbc 5550X Shredder
My shredder won't power on. It is not overheated.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
Shredder stoppped working, no display or power when restarted. Power cable is good.
Aug 07, 2013 | Universal Office Equipment & Supplies
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Royal VF1012mx Shredder Logo
899 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
