Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Range Spectra oven not working
After a close lightning strike the clock jumped ahead 4 hours but was not flashing. Reset clock and tried oven and received F2 code. Oven will not light at any temperature, broiler will laway light at any temperature oven is set to.
  • Anonymous Mar 31, 2014
    SEt clock on my GE Profile range and minutes later it jumps ahead hours
  • 5,911 Answers
F2 is an indication of an oven temperature sensor problem. Usually this is a problem with the oven sensor itself, or the relay contacts on the Electronic Range Control (ERC) board. If you had a close lightening strike, I would suspect that the contacts on the ERC are probably bad. It probably wouldn't hurt to replace the oven sensor as well. I hope this helps you.
Posted on Jul 14, 2007
My GE Profile displays "door" when trying to start oven after a self-cleaning cycle. the door opens and closes, nothing jammed in it, not stuck. There is not an associated "F" code displayed. Tried...
Try setting the oven to [CLEAN]
Then after 2 Minutes check to see that the door has locked.
After a total of 4 minutes Clear/Stop.
WAIT at least 10 minutes the see if the door then unlocks and the icon clears.
If not, then the door switch, or control board are bad.
Feb 04, 2018 | GE Spectra JBP78 Electric Kitchen Range
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Lost instructions - I have my oven cleaning how
Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Jul 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra oven
First thing to do is unplug the range for a couple minutes then plug it back in. In some rare cases this will reset the control. If this doesn't work then you will need to use a meter and check to see if you are getting proper voltage to the control (clock) and the light. If you are getting voltage to the clock then it is bad. Let me know what you find and give me the complete model # from the sticker on the range so I can look into this for you better.
Nov 19, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Oct 04, 2007 | Kitchen Ranges
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE range JBP78G
There are no known errors like that for the control so i am thinking the control is damaged.
Dec 29, 2006 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
245 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
