Question about Olympus VN-2100PC Digital Voice Recorder
Unable to delete files from the recorder
When I transfer recorded files to my PC I do not need them in the recorder any more, but pressing the button "erase" seems to have no effect. whenever I come to transfer a new file, all the old ones are transferred too although I try remove them from the recorder immediately after every transfer. I am a reporter and I have been using the thing since a few weeks already and when I need to transfer a new record to PC, all the old records keep to be transferred repeatedly with the new one. Nowadays there are 7 files in the folder A (each about an hour of talk) and it takes quite a long time to have everything transferred. Can someone help me?
    President:
  • 919 Answers
Resetting the Recorder (CLEAR)
This function resets the current time and other settings to their initial
status. It is useful if you are having problems with the recorder, or if you
want to erase the entire memory of the recorder.
1 Hold the STOP button, and hold the ERASE button for 3
seconds or longer.
2 Press the FF or REW button to select the “YES”.
3 Press the PLAY button.
Posted on Jan 14, 2009
The above solution also worked for me for a different problem. My VN-2100PC suddenly reduced it's available recording time from 5hours 53 in HQ to 3hours 20, after I had some problems with corrupted files. I deleted everything and still this was the case. I used the above solution and now have my full compliment of available memory.
Posted on Mar 10, 2009
Unable to remove all the recordings from my arcos
Transferring the recording does not earase it, you need to delete the original files from the folders, not just from the playlist.
see this manual.
Apr 11, 2010 | Computers & Internet
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Unable to transfer recording from File B
All files should be set for transfer when using the Olympus software.  There is a way you can check folder B in my computer by locating the program folder where the olympus software resides.  If folder B is empty, the recording could have landed in A, C, or D folder.
Oct 07, 2008 | Olympus VN-2100PC Digital Voice Recorder
Olympus ds-30 deleted file recovery
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
Sep 26, 2008 | Olympus DS-30 Digital Voice Recorder
Erasing
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
PLAY button.
PLAY button.
Sep 20, 2008 | Olympus WS-200S
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Ws 200s deleted files but still full
PLAY button.
PLAY button.
Mar 20, 2008 | Olympus WS-200S
Olympus VN-2100PC Digital Voice Recorder Logo
178 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
