Question about Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop
CD rom and DVD drives don't work
I'm new @ using computers. Recently recieved my dad's computer because he passed away.When I booted system and tryed to play a CD in the drive a prompt said can't play no device attached. Opened tower and noticed the module below the floppy drive was sliding back and forth.I pushed it back into position like the module below and it finally began to work.But now it's not working again. How can I secure the module into place and even though it's not secured right now it seems to be in the right position but is back to not working again. It's a compaq desk pro tower model number PS7201-2C and the connector to the module is marked P5
Thank you, sincerely James Clisset
    Guru:
  • 558 Answers
It might be the problem arised due to it worn out and not in use for a long.
Try using it after a cleaning with vaccum cleaner and wrap out dust from everywhere (means internal as external if possible)
Then reply the status after this.. as far as the description says it may need manual inspection or worsely replacement.
Best of Luck,
Scott
Posted on Jan 14, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
How to install a new operating system on my hp laptop
In almost all instances a new operating system will be installed from a CD or DVD.
1. Start your computer and enter BIOS to make sure CD/DVD is your first bootable device. 2. Have your CD/DVD in the CD/DVD drive and boot the computer 3. Boot the computer and generally you will be prompted to hit any key to boot from CD 4. A guided setup process will walk you through the installation of your given operating system
Oct 08, 2009 | HP OmniBook XE3 Notebook
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
Cannot boot windows xp
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | EliteGroup P4M800-M7 Motherboard
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Non-system disk or disk error
Is you cd-rom drive shot - are you trying to boot up your computer through an xp or windows cd? If it is, it's not going to recognize and boot up. You'd be best getting a new drive - look around for someone with a Compaq Evo 800cp. They have the same exact cd-rom drive. Here are your compatible cd-rom devices:
TEAC DW-224E-A
or a Compaq DVD-ROM DRN-8080B
otherwise try a HP SD-C2612. I have these three drives. They all work really well.
Jul 01, 2008 | Compaq Armada E500 Notebook
A DVD-ROM problem
Find a technician who can do it for you - or if you are conversant with computers you get an eternal dvd rom Drive and use it. Have you tried the floppy drive if your computer has any? or the flash disk?
please try one these options.
Dec 31, 2007 | Toshiba Satellite A60 Notebook
Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
