Question about DG Gold / Brass 98 Biometric Keyless Electronic Digital Door Lock RH
Unican keycard door locks at hotel
I dont know how to reprogram the door after i've changed the batteries. Can someone please tell me the steps??
    New Friend:
Unican card machine its keep giving a invalid card error read on main card but bellman card works though
Posted on Nov 10, 2012
4 Suggested Answers
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
  • 963 Answers
SOURCE: Unican 1000 locked out of
I don't think that you have much of a chance since the lock is doing exactly what it was made to do--preventing bypass and entry from the outside!
That said, I don't have a direct answer, but here is the contact info you need for customer service. They may be able to help you:
1-800-849-8324 (option 1)
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Kaba Ilco is in North Carolina, so it's probably best to call during Eastern Daylight business hours.
Good luck--and please provide feedback if this helps!
Posted on Aug 25, 2011
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
2000. How do I reprogram the remote control?
Go to www.youtube.com and watch this short video. It will only take you a minute to program each key fob.
https://www.youtube.com/watch?v=uOXUIfddHBU
Jun 05, 2015 | Chevrolet Blazer Cars & Trucks
How do I reprogram the garage door remote for a Chamberlain electric garage door opener
Press the learn button on the garage door opener once then press and release the garage door opener remote button.
Oct 07, 2014 | Sears Craftsman LiftMaster Chamberlain...
How to Change Batteries in a Unican Door Lock
Are you sure that your lockset takes batteries. Most Simplex brand locksets are mechanical and don't require batteries. Take a picture and post it on here and I'll be able to tell you.
Feb 26, 2013 | Locks & Locksmithing
I have a 2007 Toyota RAV 4 I can't get the remote to work after changing the battery does it have to be reset if so what has to be done. I can lock and unlock the doors manualy but not with the remote...
1. get in the car
2. shut the door
3. place the key in the ignition
4. lock the doors, manually
5. turn the ignition to on then off...do this seven times
6. unlock the doors and try your remote
Sep 20, 2011 | 2006 Toyota RAV4
Upon returning home to find my powerbolt 1000 had only partially locked, I hit the lock button again to reset the lock. It then proceeded to beep for 10 seconds and then allow nothing for a minute. I then...
I suggest changing the batteries and reprogramming the lock.
Under normal circumstances you do not need to reprogram the lock after changing batteries, but I would do it anyway. It seems to be acting like it doesn't recognize your code.
Also, you should check the alignment of the door lock to the door frame strike plate, using the manual turnlock(T-turn) to check it. If the door is misaligned, make necessary adjustment to deadbolt strike location and/or hole in door jamb to allow the deadbolt latch to retract and extend freely.
Test your lock after programming for proper operation with the door open so that you can watch it cycle.
Here is a link to the on-line installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
If, after the battery change and reprogramming you lock is still not working properly, it's time to call Kwikset Customer Service and let them help you, since new parts may be in order.
1-800-327-5625 (California hours)
or visit www.kwikset.com
One final note: I recently helped someone else with a Powerbolt that would not fully extend and retract--he thought it was an electronic problem at first. Then he removed the deadbolt assembly and found, in his words, "the deadbolt is ensconced with a plastic sleeve when it retracts into the latch housing. The sleeve is shattered and most likely to be the cause of its malfunction." Something else to look at!
Aug 31, 2011 | Kwikset UltraMax Powerbolt 1000
DG Gold / Brass 98 Biometric Keyless Electronic Digital Door Lock RH Logo
1,236 people viewed this question
Top DG Locks & Locksmithing Experts
ray gallant
Are you a DG Lock and Locksmithing Expert? Answer questions, earn points and help others
