Question about Dishwashers
Maytag mdb6650aww dishwasher is dead. touchpad won't light up. Looking for most probable reasons
  • Anonymous Jan 14, 2009
    I have the same problem. Had to manually scoop out water from the bottome of the machine after the last load of dishes was done.
I have same dishwasher, same problem. i fixed it with epoxy. inside door is the mother board and on the left hand side there is a square box looking thing that came loose, i think it is a relay of some sort (i am not a repair guy) but it was loose, i pushed it down and then edged the whole thing with 5 minute epoxy. worked like a charm no problekms since. :-)
Posted on Jan 24, 2010
  • neastguy Sep 17, 2010
    mmsaclark .. was is it blue? I'm thinking I have to solder it to the board
    Problem Solver:
  • 11 Answers
Well the most probable reason is that the wiring connectors located at the bottom of the dishwasher behind the toe panel were wired wrong and have shorted out or burned off, the next thing to look at is the control panel. (not control board, the actual panel with the buttons) you can take apart and check to make sure the ribbon cable is still connected, but most likely will be one of those two problems, If you need to get down and really dirty the next step would be to start taking voltage readings.
Posted on Jan 15, 2009
Why doesn't it work?
Dishwasher Diagnostic Touchpad is Not Working,Maytag ...
? 8:28
https://www.youtube.com/watch?v=zex_g2TJRl4
Aug 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Maytag Built-in Dishwasher which has this following issues: Touchpad System Is Not ...
Maytag Dishwasher Repair - Will Not Start or Complete a ...
? 5:06
https://www.youtube.com/watch?v=cfWUeh0ZtPY
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Built-in Dishwasher which has some of ... Dishwasher Diagnostic Touchpad is NotWorking,Maytag,Whirlpool ...
Top 638 Complaints and Reviews about Maytag Dishwashers
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1.2 - ‎185 votes
Can't push a button to choose what cycle I want, it doesn't respond. .... After 2 1/2 years the control panel on my Maytag Dishwasher will not work. This is the 4th ...
Maytag Dishwashers - ConsumerAffairs.com
My dishwasher just stopped working 1 year after purchase. .... Holding Control Lock or Delay for 3 seconds doesn't seem to clear the circuit board logic. Problem ...
Dec 12, 2015 | Maytag Dishwashers
DISHWASHER WILL NOT TURN ON WHEN I PUSH THE BUTTON. i CHECKED POWER TO THE UNIT AND IT'S GOOD.
Are you certain the door is closing at the switch,. if not, inspect the close door switch real well.
IS there any water in the bottom -- perhaps it may be clogged and refuses to call for more water (i.e. turn on).
Best regards,
Ck
Dec 03, 2011 | Maytag Dishwasher
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Maytag dishwasher model #MDB6650AWW no lights on the conrol panel Door switch has power.
if the door switch has power and you cant get the dishwasher to do anything then you will need a new control.. ..
Feb 20, 2009 | Maytag Dishwashers
Dishwaher will not fill
is the float switch stuck in the up position?either soap built up or some other object may be stuck under it.
Nov 03, 2008 | Dishwashers
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Magtag MDB6650aww dishwasher will not fill
remove the lower kick panel inside the washer is a float that goes through the bottom of the tub look under the washer and make sure the end of the safety float rod is on top of the safety float micro switch if its not it wont fill if that don't do it let me know we will trouble shoot the rest but that is probably it
May 24, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Maytag Dishwasher will not start. all lights will flash except for the start / cancel button.
I had the same problem. The plastic wiring strip that connects the touchpad had corrosion from water. The panel would need to be replaced, because they don't sell the touchpad separately. (around $50 - $70 USD)
Apr 15, 2008 | Maytag Dishwashers
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Dishwashers Logo
715 people viewed this question
Top Dishwashers Experts
