Question about Radio Shack 15-2146 Remote Control
Remote not working after programming
When i try to program my remote for use with my Sanyo TV using the remote code 0154 or 0156 the remote works perfectly fine during testing, but does not work at all once i exit the setup. Can anyone help me?
  • 56 Answers
Check the codes .. is it for your TV model or for general sanyo TV's ... if so try to look for the code of your model... please if you find this helpful rate me !
Posted on Jul 31, 2007
I need the steps to program the urc4021 remote, as well as the code for the sanyo tv
To program the One-For-All URC4021, first turn on the TV manually (or with the original remote). Press the TV button on the URC4021 once. Then press and hold the Set button until the LED blinks twice. Now you can enter a code directly and test it. For Sanyo TVs, the only programmed code is 0154 . If the LED blinks twice, press Power to attempt to turn off the TV. If that works, you can turn the TV on again and test if the other buttons on the remote work with your TV. If the LED doesn't blink twice, repeat the steps from pressing and holding Set. (If you wait too long before entering the code, the remote will leave the programming mode.)
The URC4021 has a code search mode. Press and hold Set until the LED blinks twice, then press 9 9 1 . If the LED blinks twice again, alternate between pressing the Power and TV buttons until the TV turns off. Then press Set to lock in that code and test the remote again.
I hope this helps.
(Note: if your TV is newer than the remote or released within 6 months of the remote being programmed, this code may not work. The URC4021 documentation gives March, 2004 as the copyright date. That suggests that the codes may not work with devices built in 2004 or later.)
Sep 29, 2015 | Sanyo Televison & Video
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
Sanyo 50" Plasma DP50710 Remote will not work.
Try to synchronize the remote control with an other code to your TV brand.
Jan 23, 2013 | Sanyo Televison & Video
How do you work rca univ.remote in sanyo tv.
Most likely because very few if any universal remotes will work for Sanyo-----Try to google the model of the remote to locate instructions for programming it.
Dec 04, 2012 | RCA Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Dec 13, 2010 | Televison & Video
Programming a sanyo tv with rcu403a remote and
Hello Jeffro
Programming a device using the Code Lists:
1- Sanyo 017,021,039,056,057,058 (codes)
2- Press and "HOLD" CODE SEARCH.
3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH.
6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this helps you out.
Cheers Little Dish Fitter
Oct 09, 2009 | RCA RCU403 Remote Control
Have SANYO COLOR TV - Model # DS27590 - trying to find the codes so I can program my GE universal to work with it.
I found the codes by going on line to various sites. I have two TV's a stereo, a DVD/VCR player that I wanted to program a universal remote for.
As far as how many devicces one universal will handle...I don't have the answer yet.
Thanks.
May 16, 2009 | Sanyo DS27590 TV
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
Need tv code for remote control
¿Porque siempre preguntan por el codigo para el control pero nunca ponen el nombre del control y el modelo ?
Mar 17, 2008 | Sanyo DS19310 19" TV
Radio Shack 15-2146 Remote Control Logo
46 people viewed this question
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
