Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Keeps washing the same 34 minutes has been indicaing for 2 hours, there seems to be alot of soap.
  • 1,543 Answers
If you are using a front load washer, never use more than one tablespoon of HE laundry soap per load. Now, to get rid of the suds you have: Get a package of Phyzeme (spelling?) tables for stomach gas. Cut about four of the capsules open and add the liquid contents to the washer, then resume wash. That will knock the suds right down without having to run about 10 rinse cycles through the washer.
Posted on Jan 14, 2009
What is the pairing procedure of ecu with immobilizer of Indica vista
TATA Indica Vista ECM / ECU - YouTube
? 2:26
https://www.youtube.com/watch?v=rRk5zSFA1eg
Mar 8, 2014 - Uploaded by Flip Keys
This video shows how to open TATA Indica Vista and ManzaECM / ECU for repair purpose.
How to extract Immobiliser Chip from Indica Vista key ...
? 0:52
https://www.youtube.com/watch?v=pqG0T99Xce0
Nov 8, 2012 - Uploaded by Flip Keys
If your original Indica Vista key breaks, wears-out or gets damaged then you can re-use its immobilizer chip ...
Maruti Suzuki SX4 ECM / ECU - YouTube
? 2:37
https://www.youtube.com/watch?v=pWjmh1QUhHQ
Jan 12, 2014 - Uploaded by Flip Keys
If you are repairing Maruti Suzuki SX4 ECM / ECU or coding a new immobilizer key then you can open the ...
TATA Motors INDICA VISTA Owner's Manual - ManualsLib
Jan 08, 2016 | Cars & Trucks
Tip
This is a great solution.  Our washer would take forever to finish the last...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Sep 28, 2008 | Kenmore Elite 45986 Front Load Washer
How do i know who much time it takes to defrost a whole chicken?
Defrosting times for the Refrigerator Method 5 lbs -
7 lbs -
10 lbs -
12 lbs -
15 lbs -
24 hours (1 day)
34 hours (1 day 10 hrs)
48 hours (2 days)
58 hours (2 days 10 hrs)
72 hours (3 days)
Jan 25, 2011 | Microwave Ovens
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Water is not drainig from bottom of dishwasher
normally its two things, 1 over sudzing or 2. or a semi clogged drain. over sudzing can be caused by using jet dry and let say a cascade with a jet dry shine that can cause the unit to have alot of soap. in some units the way it operates is that when the sensors see there is alot of soap it will keep rinsing to get out soap until it cant rinse no more.reduce with a regular soap with no extra jet dry,your drain may has to be cleaned it might be a slight blockage. let me know how you made out.
Feb 23, 2010 | Dishwashers
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Print cartridges #34 & 35 won't work in my Lexmark x2580 printer.
The cartridges compatible with the Lexmark X2580 printer are given below:
18C0190 - #2 color cartridge.
18C1530 - #3 black cartridge.
However, if you are a residence of USA or canada then you can call Lexmark technical support, so that they will replace the #2 and #3 cartridges for you free of cost.
you may call at 1-800-332-4120
hours of operation are given below:
Monday to Friday: 8 AM to 11 PM EST. Saturday: 12 PM to 6 PM EST.
Apr 10, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Cleaning cycle
bleach goes in the bleach area. no soap or clothes in the washer. close the lid and hit the power & clean washer buttons. should run for 60 minutes, but check it after an hour to make sure it is complete. mine ran (malfunctioned) for over 3 hours indicating 7 minutes left.
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
