Question about Samsung CLP 300 Laser Printer
Printer does not respond and print
Status has a solid red light , also 3 color dots have red light
  • hoosbekah Feb 03, 2009
    I understand that the red lights beside the colors mean that I am out of toner. What I do not understand is why, when I am printing something that is just plain, black text, I need to have the color cartridges full?
You are out of toner
Posted on Jan 17, 2009
Goodman gmp100-3 furnace The furnace will not start when I turn power on. It will hum but no click. The status light is solid red. Could the ignitor be bad? And what color should it be?
You should hear the ignitor pop. If you don't hear that pop sound, then the igniter is bad. They are easy to change, just make sure you turn the gas off and the pit-cock into the appliance and take a photo of exactly where the igniter tip is oriented so you can put the new one in the same spacing to have it ignite properly. The status light should be green when the furnace is 'On.'
May 09, 2015 | Goodman Heating & Cooling
New member here. I have a 62" DLP Mitsubishi model #WD6252. I've already replaced my lamp AND ballast and continue to have the solid red lamp status indicator. I've made sure the connection from th
Your color wheel is failing or has failed. the red light ONLY means the lamp cannot light or was forced to shut down. it means nothing about the lamp or ballast specifically.
If your color wheel isnt spinning up correctly or you have a stuck fan somewhere, the lamp will be shut down immediately upon startup.
Id check to see if the color wheel is stuck or if its getting stuck.
Dec 17, 2014 | Mitsubishi WD-62525 62" Rear Projection...
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Mar 06, 2011 | Mitsubishi HC3000U Multimedia Projector
Creo eversmart supreme Mrk 1 solid red status light
There's either a problem with the power supply or the control board, most likely the control board. Have you tried running the diagnostics yet?
-Ryan
omnicow at gmail dot com
Dec 01, 2009 | Creo Office Equipment & Supplies
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Samsung CLP 300 Laser Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
