Heater Lamp Does the fuser assembly include the fuser heater lamp? Thanks.
  • 390 Answers
The short answer to your question is "Yes" it is included in the fuser assembly!
Long answer:
The heater lamp is an integral part of the fuser assembly. It is located inside and heats up a metal bar or roller depending on the fuser's style then then heat actually melts the powdered toner into the paper. The heater lamp usually is not easily removed from this assembly. If you did want to do it yourself then you've got to be real careful as it is very fragile and no oils from your fingers must be applied to it as it will shorten its life.
Good Luck!
Rich Lilja
Posted on Jan 14, 2009
Kyocera FS1118, error code C6000,how do I resolve this?
C6000 code is a fuser that failed to warmup.
Broken fuser heater lamp wire
The fuser temperature does not rise
after the fuser heater lamp has been
turned on.
Tttt
To resolve you will need a tech to replace parts in the fuser assembly.
Aug 26, 2014 | Office Equipment & Supplies
Kyocera error 6000:0032718
6000 Broken fuser heater lamp wire
The temperature does not reach 100/
212 after the fuser heater lamp has
been turned on continuously for 30 s.
35/37 ppm printer (EUR/USA model):
The temperature does not rise by 1
1.8 after the fuser heater lamp has
been turned on continuously for 5 s during
printing.
Apr 15, 2014 | Kyocera FS-2020D Laser Printer -...
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Jan 31, 2011 | Kyocera FS-2000D Laser Printer
At startup the Minolta 1031F as a flashing C 50 on the screen
Verify the continuity of the fuser heater lamp.90% the lamp is open.You need change the fuser lamp and the fuser roller(the heater lamp is in the roller and is not detachable).
Nov 03, 2009 | Minolta EP1031/1031F CS/PRO Copier
My kyocera photocopying machine is asking me to callservice 6000 what can i do/ what does it mean?
6000 simply means Broken fuser heater lamp wire
The temperature does not reach 100°C/212°F after the fuser heater lamp has been turned on continuously for 30 s. The temperature does not rise by 1°C/1.8°F after the fuser heater lamp has been turned on continuously for 5 s during printing. 35/37 and 45/47 ppm printers (EUR/USAmodel):
Fuser thermistor M detection temperature does not rise by 1°C/1.8°F
after the fuser heater lamp has been turned on continuously for 10 s during warm-up or at standby.Fuser thermistor S detection
temperature does not rise by 1°C/1.8°F after the fuser heater lamp has been turned on continuously for 5 s during warm-up or at standby.
Poor contact in the fuser thermistor M connector terminals.Reinsert the connector (See page P.1-5-19).Fuser thermistor M installed incorrectly.
Check and reinstall if necessary (See page P.1-5-19).Thermal cutout
triggered.Check for continuity. If none, replace the thermal cutout (See page P.1-5-19). Fuser heater lamp installed incorrectly. Check and reinstall if necessary (See page P.1-5-19).Broken fuser heater lamp wire. Check for continuity. If none, replace the fuser heater lamp (See page P.1-5-15).
Oct 26, 2009 | Kyocera FS-1118MFP Laser Printer
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
Heat lamp for clc 1000
Heater lamp could be burnt out.
Heater lamp connections
Thermal fuse
Thermistor
Control board for the fuser.
May 01, 2009 | Canon CLC 1000 Color Copier
Service Code of H4-01
H2-01 Fusing Temp. to low
Use DIAG (SIM5-2) to checkthe heater lamp
Blinking operation.
If the heater lamp blinksnormally:
Check the thermistor and its harness.
Check thethermistor input circuit in the
control PWB.
If the heater lampdoes not light:
Check for heater lamp disconnection and
thermostatdisconnection.
Check the interlock switch.
Check the AC PWB andthe lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble.
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKINGON MACHINE***
You have to reset fuser errors with simulation 14.Push P * C * then 14 then Start (the button you use to make copies)and it should reset the code. If not then replace the fuser.
SM5-1 should turn the lamp on. If lamp blinks on and off it is thethermistor, if it does not it is the lamp, but check the contacts onthe lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defectivereplace.
Jan 25, 2009 | Sharp AR-M237 Copier
Call service 6000:0098269
30/31 ppm printer (EUR/USA model):
printing.
model):
printing.
Poor contact in the
fuser thermistor M
Fuser thermistor M
P.1-5-19).
Thermal cutout
triggered.
Fuser heater lamp
P.1-5-19).
Broken fuser
heater lamp wire.
Sep 02, 2008 | Kyocera FS-3900DN Laser Printer
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
