Question about Frigidaire FEQ1442ES Electric Dryer
No pwer in Control panel but light is on the the dryer
My dryer seems to be partially working. There's power coming in for sure because the light lights up in the dryer. But there's nothing working on the front control panel. No light, nothing. I tried to press all buttons but no "response". Can somebody help me?!?? Thanks!!
  • 1 more comment
  • moongdss81 Dec 01, 2007
    i am having the same problem. the drum light comes on but nothing on the panel lights up or beeps as i try to turn it on. i pulled it out of the space it was in and unplugged it then plugged it back in. before and after replugging it i flipped the breaker in case that was the issue but still nothing. i live in an apartment complex, is there something that could be an issue with a building breaker? i have no idea what to try next and am not sure what i would be looking for if i managed to open it up. please help!
  • jessie034 May 10, 2008
    Same problem with this dryer. just brought it home; connected properly we're sure of it. not the breaker. no lights/ no go. doesn't seem like there's power going to it ??
  • Anonymous Sep 23, 2008
    plug the dryer up all lights goes out and dryer too.
    Scholar:
  • 71 Answers
You may have blown one of the two circuit breakers at the building fuse box. Sometimes they are physically linked together so that both trip at the same time. This is how it's suppose to work but sometimes one will trip leaving you with half power but enough to work the minor circuits. Resetting the circuit breaker is an easy fix. If this doesn't work ohm out the thermal fuses. They are ususally accessable by lifting the top. With it open check that all connector are connected.
Posted on Jun 30, 2007
Have a kenmore he4 front load gas dryer. It would go completely dead like it had no power... intermittedly working... we replaced the control board. Seems to come on fine now however the end of cyc
is the dryer sensing strips clean? Could be some dryer sheet goopus on them causing intermittent sensing to clothes?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2017 | Dryers
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
No power to selector panel
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
Maytag (2002) electric dryer quit working, has no power.
Part number LA-1053 is a high limit t'stat/fusable link kit. A restricted vent is the number one cause for failure of these components.
After making sure vent is thouroughly cleaned you may want to have a pro come out to install the kit. If you decide to tackle it yourself, mmake sure POWER IS REMOVED from dryer, prior to attempting repairs.
Nov 04, 2009 | Dishwashers
Have power on main line but dryer won't run and light in tub doesn't work
check to make sure both sides of the outlet have pwer present, if not, repace outlet or correct wiring problem, as well check to see power cord hooked up correctly on dryer.
Jun 30, 2009 | Dryers
Kenore Senor Smart 27-inch dryer control panel not working
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 20, 2009 | Kenmore 72062 Gas Dryer
Whirlpool dryer MOD: GEW9868KQ2 - touchpad not working
Aug 16, 2008 | Whirlpool Dryers
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer problem
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
180 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
