Question about Maxon GMRS50 (16 Channels) 2-Way Radio
Radio will not stay charged. Battery replaced. Problem persits.
The radio works fine for several minutes. Then it starts to beep and stops working.
  • 40 Answers
Does it look like the charger is working?
Batteries have a life of 1-5 years depending on how they are used. Check ebay for a new set of batteries.
Posted on Jan 23, 2009
Starting problem (see details), on 1998 Town & Country.
Check your battery cables and starter cables especially the connectors and bolts under the hood. The bolts and connections could be loose or corroded. Check the connections near the battery and on the battery since many times mechanics mess with these the most. My guess is something is loose if it starts well most times, but fails occasionally. Did you look for blinky codes or DTCs? A '47' (or P0562) could mean a bad battery or alternator, and a '12' (or P1684) could indicate intermittent connections. Do the dome lights dim or stay well lit when the clicking is heard during cranking? If so, then the issue is most likely near the battery and if not then the issue is more likely near the starter. Good luck. There are a lot of wires under the hood.
Oct 10, 2017 | Chrysler Cars & Trucks
I put in a new battery and now the radio beeps when it is keyed up. I put the old battery back in and it works fine. Both batteries fully charged. Any suggestions?
A beep when keyed up can mean a low battery.
1) It is possible your new battery did not take its initial charge, it can take as many as 3 chargings to 'jump start' a new battery. You might try charging the battery an addition 2 full charge cycles.
2) Try the new battery in another SP50 radio to see if it works, or test with a volt meter, if available.
3) Double check the battery is the correct HNN9018 or equivalent NiCd battery. If you are using an after-market battery, check to see if it is a NiCd. If it is a NiMH battery you will need a fast rate charger to charge it up. (On an SP50 the fast rate charger has a blue button on the tray which needs pressed to put it in fast charge mode)
4) This may sound silly, but check to see you installed the battery the correct way. On a Motorola battery the STOP sign would not be visible when installed correctly.
5) If all these items do not solve the 'new battery' problem, you should return the battery to the place of purchase for an exchange.
Best regards.
Sep 17, 2011 | Motorola For SP50 7.5v 1500mAh NiCd...
When pushing the push to talk button either on the radio or the headset cord I get a loud beep over the speaker and the radio won't transmit. I have replaced batteries, reprogramed unit still no fix. Any...
Two thoughts, I know you've replaced the batteries, but this can be a sign of a low, bad or weak battery. You might check your charger to see that the light is coming on and staying on during charging. Also, be certain the radio is shut off during charging.
Secondly, be certain when using any audio device the radio is shut off when plugging in the audio device. And the device is designed to go with the radio you are using it with.
Troubleshooting thoughts: 1) Try a battery directly out of a working radio to see if the problem stops. If the problem persists, you have a radio or device problem. 2) Try the radio without the audio device, with a known good battery. If you still have a problem, you have a radio problem. 3) Try your audio device on a known good radio. If there is no problem, your audio accessory is okay.
Best regards.
Oct 19, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My radio on my 2007 chevrolet aveo stop working. It is dead. It is like there is no power.
This happened to me and the next time I beeped the horn the radio came back on. Then for a long time radio would only come on if you beeped the horn. Battery has since gone dead, when I jumped it the radio now works fine. I am convinced wires are crossed and radio still sucks juice from the batttery even when the car is off. Battery stays charged and starts car if you make sure radio is off before shutting car off for the night. Am taking it to the dealer a.s.a.p. So long story short see what happens when you beep the horn.
Sep 12, 2010 | Car Audio & Video
Radio won't show display.....
Radio fuse sounds like a logical place to start. Be sure you check all your fuses. Theres probably more then 1 for the radio
Jun 04, 2009 | 1997 Volkswagen Jetta
2000 catera radio stopped working
HAD the same problem and it turned out to be the battery even though all system (i.e. charging, alternator, etc.) were good. Noticed the voltage meter would dip while driving then show a charge when first starting. Bottom line is battery was not holding the proper charge whiel running due to a short in the battery. New battery seems to have taken care of the problem... oh make sure the terminals are really clean.
Nov 05, 2008 | 2000 Cadillac Catera
Will not work on battery
Try removing the battery cover and remove and disconnect the battery.
Reconnect the battery and replace the battery cover.
Now, plug the radio into the wall electrical outlet and wait, the blue light on the radio top should start flash and will flash for about 10 minutes and then stop flashing.
Leave the radio plugged in for about 16 to 24 hours to completely charge the battery. For the first three or four times, completely drain the battery and completely recharge for 16 to 24 hours, this will condition the battery .... mine works like a dream. GR
Feb 16, 2008 | Teac R1 FM/AM Radio
Bad battery, Buy new one on ebay. Carl
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Maxon GMRS50 (16 Channels) 2-Way Radio Logo
82 people viewed this question
Top Maxon Radio Communications Experts
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
