Question about Maestro Lutron MA-T51 Countdown Timer 5 to 60 minutes
Looking for a timer for a gas fireplace
I have a gas fireplace in my bedroom that I would like to put on a timer so it will shut off after I go to bed. The fireplace has a standing pilot light and two switches. One switch is for the fan and the other is a low voltage connection that turns on the fireplace. I want to replace that switch with a timer that allows me to turn it on when I go to bed and have it shut itself off after 30-60 minutes.
Will the Lutron Miestro timer work for this?
  • davezollinge Jan 14, 2009
    Tried them both and they didn't know.
After searching quite some time on this same problem ive yet to find anything but the spring timer which doesnt require power to work not what my customer wants though, or a wireless system which will require batteries and some work in the fireplace...uck
Posted on Jun 03, 2010
Home depot or lowes
Posted on Jan 14, 2009
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
I have a marco 36" standing pilot natural gas fireplace. Model is either 794015C or 794019C. It has bi fold doors. I don't know if i need to have doors open or closed during operation, or if it matters...
Small lava rock on bottom (can be bought where you buy gas grills, fireplaces and their parts. The embers at a fireplace shop. Doors open when using and closed when not. If doors are closed while fireplace is being used, they get extremely hot and may burn someone not expecting them to be hot.
Jan 18, 2015 | Home
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Charmglow natural gas fireplace, CQN300TQ, need a manual
looking where to buy a thermocouple for natural gas fireplace cgn 300tq
Nov 01, 2011 | Napoleon 36" Zero Clearance Top/Rear Vent...
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Fireplace clicks and shuts off when running
There are a few things that could be causing this problem. The most common resolution to this problem is making sure the thermo couple is screwed tight into the valve. While looking at the gas control valve, you'll see a few wires and small metal tubes going into it. The one you want to tighten is the tube that is copper. Even if you get only a half a turn on the little brass fitting that's holding it screwed in, that's usually enough. If that doesn't do the trick let me know and I'll get back to you with some other things to try.
Jan 21, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a Peterson Real-Frye ceramic vent-free fireplace/ log set in my bedroom and my problem is that the log set constantly shut off and the piole goes out. What is my problem and how can this problem be...
there is a thermocouple which is a piece of metal that sits in the pilot flame if this is not in the flame the pilot will go out if this is bad the pilot usually will not light or stay lit let me know if this is useful or of any ?'s
Jan 06, 2009 | Heating & Cooling
Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
Dec 30, 2008 | Intermatic 600 Watt Low Voltage...
Intertherm Fireplace - Model BM36HCD
Am Looking For same pipe for my fireplace
Apr 26, 2008 | Intertherm Heating & Cooling
Maestro Lutron MA-T51  Countdown Timer 5 to 60 minutes Logo
917 people viewed this question
Top Maestro Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Maestro Hardware and Accessory Expert? Answer questions, earn points and help others
