Question about Goodman GDS80904BNA Open Flame Heater
Air flow seems low
I want to speed up my blower motor but the diag is unreadable
Ok dose this model furnace have a circuit board? if so there should be markings on the board where the blower leads are attached. such as cool heat park/or un used motor leads. and to speed up your blower it is going to be either the red wire or black wire they some times alternate you will have to see how the blower sounds or feels.. but you are going to replace the wire going to the heat terminal with a red or black wire and see how that works for ya. just makesure the power is off before sticking your fingers in there... also it may seem too obvious but ill say it anyway check ait filter and make sure all your dampers are open properly on the supply duct work
Posted on Jan 22, 2009
Low air coming out of vents ,blower is working
resister either defective or wire incorrectly probably, try running jumper wire to motor to see if it has full speed.
Feb 01, 2016 | Cars & Trucks
Is there a filter for the cabin compartment,heater blower motor filter?
no cabin filter but u might have a failing blower resistor if the fan isn't working on all speeds
Mar 07, 2015 | 1995 Buick LeSabre
Low air flow to feet when heat is on ?
Sounds to me that you might have a leak in the line. Those heaters are all Vacume actuated.
Feb 18, 2014 | 2000 Oldsmobile Intrigue
On my 1998 olds 88 I don't seem to have a good volume of air coming from the vents. The fans blow the a/c is cold but just not good air flow. How can increase the air flow?
Hello and welcome to FIxYa!
You may want to check on the vents for it can be closed half way. If the vents are good then the problem will surely be on the blower itself. It can be worn out that's why the blower motor blows weak. Once replaced I believe you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
Aug 09, 2011 | Oldsmobile 88 Cars & Trucks
Ac fan speed
Replace the blower motor resister,this is the speeds for the blower motor,it is located very near the blower motor,and is mounted on the blower box,and it actually goes inside the box,to keep it cool.The reason for it`s failure is the blower motor,even though the blower motor sounds,and runs good,it is drawing too many amps.If this was at all helpful,please rate,thank you.
Jul 27, 2010 | 2001 Ford Expedition
No heat or air
Check the blower motor speed control resistor pack is ok.
(The resistor pack is usually located in the blower fan ducting in the air flow).
Check condition of electrical connection terminals on the blower motor circuit - these terminals pass considerable current and over time may fatigue overheat and loosen.
Check operation/replace any blower motor control relay,
Check the blower motor will run if +12v directly applied to the blower motor.
Check operation of the blower motor speed control switch is ok.
Oct 08, 2009 | 1993 Dodge Dakota
I HOPE I AM USING THIS PROPERLY......MY ? IS IN MY
The indoor blower motor is sometimes a 3 speed motor.The heat usually works on low or medium speed.But the a/c is usually on high speed,this gives greater air flow across the evaporator coil to give you better cooling,also better air flow at ducts.These speeds are usually wired through a relay in the inside unit (air handler).They can be changed.If you go to thermostat and put the fan switch to "on" the blower should operate on "high" speed.With the fan switch set to "auto"the operation will determine the fan speed.Hope this helps. Gregg
Jun 04, 2009 | Heating & Cooling
2002 saturn heater
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing.
Nov 23, 2008 | 2002 Saturn Sl
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
