Replacement for ic804 for lg dvd radio casette player LPD103-A0
The ic in the main board heats up when the set is switched on, and the player does not function
Slinteriors
  • 8617 Answers
SOURCE: WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Posted on Jun 23, 2008
JustJeeps
  • 74 Answers
SOURCE: setting clock on stock radio/CD/casette player in 1999 Dodge Ram
push and hold the clock button until the hrs flashes then use tuning button to change numbers or if your radio had 2 small pen tip buttons that read hrs & min pushing these with a pen tip will set the clock
Posted on Dec 04, 2008
ftw1952
  • 10319 Answers
SOURCE: Alfa Romeo 166 ICS Radio
The audio board is at fault. Take the unit in for repairs at any car dealership. They can send it out for repairs to any center that repairs radios for cars
Posted on Sep 11, 2010
  • 82 Answers
SOURCE: Looking for a good Philips part number for IC7003
YOU CAN GET THE DIAGRAM AT GOLDENLEPRICON. COM THEY ALSO CARRY PARTS THEY MIGHT BE ABLE TO TELL YOU WHAT PART IT IS....
Posted on Dec 07, 2010
  • 5370 Answers
SOURCE: Repair technicians have determined that a crack in
You will have to try sears parts direct site for your AIWA XR-DV526 system parts.They deal with its parts. Click on this link directly:--- http://www.searspartsdirect.com/partsdirect/part-model/Aiwa-Parts/Video-equipment-Parts/Model-XRDV526/1547/0332005/50019277/00001?blt=06&prst=&shdMod= ---------------- You can also also call sears at their service center and ask for the parts availability, Call sears :1-800-252-1698
Sales:--Monday - Friday 6:30am - 10:30pm----------
Saturday
7:00am - 9:30pm--------
Sunday
7:30am - 9:30pm---------
as you mentioned that main board is not available, if at the sears they say the same thing,then ask for the another substitute board for your player,if available.
Keep updated.Thanks.Helpmech.
Posted on Jan 15, 2011
Samsung TV, UN60EH6003FXZA, Black screen, has audio. Replaced t-con board and TV worked fine for 5 minutes, then black wave came across screen. Can replace main board, is the new t-con board ruined?
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
https://electronicshelponline.blogspot.com/
Oct 26, 2016 | Samsung Televison & Video
Vizio TV has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
My screen is flickering on and off on Vizio LCD TV? I was wondering if it was the main board or the T-Con board.
Flickering can be either with the fault to its back-light inverter or with its main power supply regulator board.
Sep 25, 2015 | Vizio E320i-A0 32 Class LED Smart TV
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Aug 07, 2015 | Vizio Smart TV keyboard remote control for...
My lg rh387h dvd wont go past hello screen
It shows that the memory IC of this set is corrupted,this is pre-programmed IC that can be replaced with the same programmed IC to solve the problem.
Feb 04, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have a red verticle line on my tv
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X same as many other LG models. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable. John
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Dec 23, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
My LG flat screen has red and blue line
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Oct 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Ic replacement
Replace both IC's or you will re-visit later! STK-392-110 X 2....
Nov 10, 2007 | JVC AV-48WP74 48" Rear Projection...
LG DR-4810 DVD Displays " PLEASE WAIT"
to open the tray during "please wait", remove casing then loosen front panel (clips either side and underneath). Power up to get "please wait", then press small microswitch in bottom right corner of the DVD player unit. Have you tried resetting the unit (turning on and holding the power button for at least 5-10 seconds)? Have you tried unplugging the unit for a longer period of time (24 hours)? get your firmware upgrade through here(sorry its in german, you might be able to get an english of it through the LG site) - http://www.lgupdate.de.ms/ two cd's- bootloader.iso , update.iso Good luck
May 16, 2006 | LG DR-4810 DVD Recorder
91 people viewed this question
 Grubhead
Grubhead
