I lost signal to my monitor. I was in the middle of working and it just blipped off and gave me the...
(More)
I lost signal to my monitor. I was in the middle of working and it just blipped off and gave me the color bar/test pattern thing that bounces around the screen saying no signal. I already tried replacing the monitor cord. Neither the analog or the dvi connection works. It won't work on other computers but other monitors work with my machine so it is not the video card. I like this monitor and would like to fix it.
Buens noches .. tengo un monitor DELL2005FPW 20,1; y mi problema es que tiene 2 imajenes mezcladas,...
(More)
Buens noches .. tengo un monitor DELL2005FPW 20,1; y mi problema es que tiene 2 imajenes mezcladas, tambien en los recuadros de vídeo y de los menús de ajustes. La imajen Aparece distorcionada, como si tuvieramos entre abierta una perciana horizontal (UNA PERSIANA DE LAS DE VENTANAS ) gracias por su ayuda.
windows jump vertically to bigger size and back again rapidly. This can happen when opeing control...
(More)
windows jump vertically to bigger size and back again rapidly. This can happen when opeing control panel it is not limited to internet explorer screens. it can be stopped by right clicking on the taskbar and closing. it makes the pc unusable until powered down and restarted.
I need to replace the ribbon cable from the switches on the front panel and cannot find one. Also...
(More)
I need to replace the ribbon cable from the switches on the front panel and cannot find one. Also connector end pieces.
i have a dell 2005fpw now when turn on after about 20second after windows finish loading i get a...
(More)
i have a dell 2005fpw now when turn on after about 20second after windows finish loading i get a whole lot of verticals down the screen, with of different colors. you can still see the image on screen it is still quite clear, although the center of the screen moves down to where the taskbar is as well of a whole lot of flickering. not to sure what the problem is. have tryed this monitor on two computers with the same thing result. so the problem must be in the monitor. any help would be greatful thanks.
