Question about Acer TravelMate 508DX Notebook
Broken hinge The hinge broke and now it's very hard to open and close the lid, so I want to disassemble the case so I can try to fix it somehow. Even having the lid be a separate part that can be locked in two ways (closed or open) would be great. But I have removed all the screws I could find and it still won't come apart, I don't want to break the case if I can avoid it.
    Genius:
  • 2,985 Answers
It is a snap together construction. a fine blade along the seam perhaps But if you have doubts about that I certainly would have- How about Gaffer tape? I have made many hinge type repairs [not a lappie admittedly] on stuff like the tool cover on a vacuum cleaner- it gets tacky after a while and will need replacing- but far better that trying to rip a clam shell apart.
Posted on Jun 14, 2007
SOURCE:
Scanner lid hinge broken or missing
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP Officejet 6700 Premium E-All-In-One
Replacing laptop hinges
There are 2 set of cable that run from the display to the monitor, be very careful with it. In most cases, to remove these cables you need to disassemble the whole laptop. Now, since you are on Y changing the hinges, I think you can do it, just don't pull on the monitor too hard, and it needs to be place on a flat surface very close to the laptop. It's not that hard, you just need to be careful, that's all.
Jun 20, 2013 | Gateway 7330GZ Notebook
One side of the printer will not close
The hinge underneath could be broken the only way to fix this is to remove the plastic hinge.. You will need to unplug the printer and examine it, the broken hinge is likely to be impeding the lid from closing,
Oct 01, 2012 | Dell 948 All-In-One InkJet Printer
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
My Dell Inspiron 1318 laptop just broke at the hinge, or something inside the hinge casing popped. I lifted the laptop by the screen..now you need to keep it at 45 degrees open. The plastic casing at the...
it can be fixed, most things made by man can be fixed.
that is if not too old and no parts sold on earth. happens.
any old PC of any kind, the maker has no parts.
(mechanical) after maybe 3 short years, (sux yes)
leaving only one place. fleabay.com
ever see them?> find a new base with no hinge mounts wrecked
is the only way,
no its broken
lots of laptop fail like this, its only cheap plastic base.
if its forced to hard or lid closed with objects in the way
the cheap plastic mounts snap,
it needs new bottom case.
Dec 31, 2017 | Dell Inspiron 1318 Notebook
Macbook lid wouldnt close, now it closes but catches when it is opened it is not smooth open and close.
Either hinge inside the case is bent or the "lid" is bent. the only way to fix this is to replace either the "lid" or internal hinge.
Aug 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The plastic hinge on the cover of my HP 3210 printer cover is broken and a nearby electrical connector has been disconnected. can you fix the problem or suggest someone who can.
Me 2 I was changing a the yellow cartridge and try to close the lid and POW the hinge on the right side broke. I got the printer opened and had to disconnect three ribbon cables the 3.5 mm jack and one 6 pin connector plug.
Apr 28, 2010 | HP Photosmart 3210 Printer
Lid support broke
Not much info but if you mean the lid on your DS falls backward when opened then one of two things has happened either the small barrel lock in the hinge has broken, this is rare. Or you have broken the hinge allowing the barrel lock to rotate in the case.
The barrel is cheap and a very easy fix by opening the case removing the led lens holder then change the lock. If you have broken the hinge you will need to replace the case, tricky job requiring patience especially when transfering the top screen to the new case. Watch a few you tube instruction videos to get a better idea of whats involved.
Jun 10, 2009 | Nintendo DS Lite Console
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Acer hinges hard to open google says known issues,will not fix says normal already cracked case above left cant figure how to open
Appreciate the direct "Ask Me".
To your concern; hinge repair is relatively easy, what is more challenging is opening the lid and figuring out how to improve the hinge action to reduce the stiffness of closing the lid. For a pictorial illustration on how to open the lid cover to expose the hinge, please reference this page. For a generic how-to on hinge repair, pls check this out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Acer Aspire 5100 Notebook
Acer TravelMate 508DX Notebook Logo
182 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
