Question about Dell Inspiron 1525 Notebook
Good morning this is carlos reyes I have bouht a gateway loptop last month and the network wireless is not working so please I need your help im in miami florida
    Genius:
  • Dell Master
  • 1,102 Answers
Open control panel
network connections
if you see the connection there right click then if you see enable click it if not click repair
if you have no connection in there let me
do you see the icon in task bar for wireless
Posted on Jan 22, 2009
Hi i need to find the sim pin number for my samsung s3 im on the three network
Have you tried the last 4 digits of your phone number? Its usually a good place to start and is a default security passcode. You may need to contact you service provider for more help.
Jan 30, 2014 | 2004 Ford E250
How do I get the drivers for gateway loptop NV51B35u
You can get the drivers in the website of gateway. Look for Drivers and Downloads in the support section in the website's menu bar. GO here
http://us.gateway.com/gw/en/US/content/home
If you want to automate the driver updates and installation in your computer, then you can also install RadarSync which is an automatic updater.
I hope this helps!
Carlo
Jan 25, 2013 | Gateway Computers & Internet
I want to bring back my miniport sstp network adapter from microsoft 6216 ver 6.0.6001.18000.possible to istall it back again same as before when i bouht it my laptop name is compaq presario cq40-339Tu...
just a note for folks out there with similar problems, note the part above that says 802.11b <this is very important as if the wireless card is a b series it can only connect to b series or older modem/routers
for example if you had a g series modem/router (802.11g) then only a 802.11g or newer 802.11n receiver card can connect to it properly,
hope this helps and good luck, if you found this info helpful then please rate us
Oct 13, 2011 | Linksys Network Everywhere NWP11B 802.11b...
Hi. I have a Vigor 2910g router. The router is working. Im trying to change the configuration, but i cant access the web page. Im connected directly to one lan port. I type the router IP in the web browser...
These are the general steps to all wireless connectivity.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Jan 31, 2011 | Draytek Vigor 2910G Dual WAN secure...
Hi, im trying to find out the password to my
HI,
If you have any computer hardwired to the router than click on start >> go to run >> type cmd and press enter >> type ipconfig and press enter >> this will show you an ip address, subnet mask and default gateway >> note down youe default gateway >> open an internet explorer and type the default gateway in address bar for example : 192.168.1.1 and press enter >> it will ask you for user name and password >> by default user name should be admin and password should be admin/password. >> after logging in to the router page go to wireless security and check your wireless network key.
If you fail to do this than you might have to reset your router and have to re-configure it again.
May 15, 2010 | Computers & Internet
Hello sir . I have taken a belkin wireless G PCI card last month.i am using in the institution provided wi-fi net work in the hostel. Card catch the network but detach immediately and also not carry pocket...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 29, 2009 | Belkin - F5D7000 - 54Mbps 802.11g Wireless...
Do i have to purchase a Wire-less Network Card in order to use a wire-less connection?
if you really want to create your own wireless network, first of all you need to make sure that you have a wireless Broad band router and for your computer to wirelessly you need a wireless adapter that will be the receiver of the wireless signal from your router....
May 26, 2009 | Gateway Essential 400 PC Desktop
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Dell Inspiron 1525 Notebook Logo
53 people viewed this question
Alun Cox
