560 Electric burr grinder - My mother in law installed the blade upside down and I can't get it to even budge much less come out. Is there a special tool to get the center screw out? Will that release the blade. Thanks
Order that I have tried successfully is the bearings at the bottom in the slight depressions, springs through the little sleeves in the grinder post placed on top of the bearings. Then secure the grinder post with the center screw. Be sure the springs are all the way through the sleeves and resting on the bearings.
I did this, too. Tell your M-i-L not to feel bad--it's an easy mistake. A Torx T20 driver will remove the center screw. However, when you remove the rotating blade, 3 springs and 3 bearings will come flying out. I'm not sure what order they go in when you reassemble the grinder. I reassembled the unit, and ever since it has not been able to grind the coffee quite as fine as I would like. Have not been able to find any info, such as an exploded parts diagram, to tell me the proper assembly.
The page at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down has a solution that doesn't require disassembling the unit -- I'd try the manufacturer first (800-220-5701) before taking anything apart.
ever find a solution to reassembling the unit
