Question about Jabra BT150 Wireless Headset
Switching to new phone
I read the one about how to switch to a new phone but is there a way to do it without the use of the old one because I don't have it any more
All you should need to do is turn on the bluetooth setting on your new phone, turn on the bluetooth headset, and then find the device on your phone.
Posted on Jun 13, 2007
Starter switch
Afraid so. The sensor in the old switch read the chip and communicated to the computer that it was good to go. Without the chip or the sensor, I doubt if your computer will work. Check with a dealer to be sure.
Jul 16, 2013 | 1991 Cadillac Seville
Handlebars brake switch replacement
It is a plunger style switch and is located inside the right handlebar contol. Cut the wires about 2 inches or so from the old switch. Solder the wires from the new switch to the wires you cut from the old switch. Cover the solder joints with heat shrink tubing. Be careful when reinstalling the front brake lever so you don't damage the plunger on the new switch.
Jun 16, 2012 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
How do i remove an ignition in a gmc jimmy 2000 without a key?
Hello, Dan. First, disconnect the negative (-)/ground on the battery Dan are you mechanically inclined. If not then don't attempted this job.
You will need to remove all the plastic covers on the steering column. Remove the horn ring.--two screws under the steering wheel. Remove the horn ring and disconnect the horn plug. Remove the steering wheel nut. Use a steering wheel puller to remove the steering wheel.
Remove the turn signal switch that fit around the upper part of the steering column. Then remove the some of the parts that are associated with the steering wheel and/or column.
Now, look at the ignition switch flange, it a big chunk of aluminum. Now look for a large aluminum dowel pin 5/8" in diameter that is driven into the chuck of aluminum but it is parallel to the steering column.
This aluminum dowel pin will have to be drill out before you can get ignition housing off, If there is adjustable steering column lever, remove this also.
Now, once the dowel pin has been removed, looking for a **** in the ignition housing. Take chisel and insert into this ****, drive the chisel into the **** until the ignition housing is loose to be remove by sliding it up over the steering column.
If you buy a new ignition switch, on purchase the switch with keys. Don't buy the hole new ignition housing.. If you do it will get expensive.
In the ignition (old) housing drive out the ignition switch pins that keeps the ignition switch in the housing. Install the new ignition switch re-insert the ignition switch hold pins.
I am fairly sure that Carquest/ NAPA some other larger auto parts will have ignition housing bolt. If they try to sell you a replacement aluminum dowel pin don't buy it. It is almost impossible to install the aluminum dowel pin without the proper tools, so use a bolt to squeeze ignition housing together.
Before putting everything back together. Now, check the new ignition switch to make sure it works. I wish you lot of luck. GB...stewbison
Sep 27, 2011 | 2000 GMC Jimmy
I don't like the new inbox I want the old one now if you won't switch me you are forcing me into something that I hate and I will end canceling my internet
Please don't be upset. The switch was mandatory at some point, but Yahoo does know that there are issues with the new version.
To switch back, sign into your mail account. Click options on the right hand side of the page, and click switch to mail classic.
This will switch your account back to the old version.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 20, 2011 | Yahoo Mail
I have a 2000 dodge ram 1500 4x4. my headlights don''t work but if i hold the bright light switch back like i''m turning my brights on, my lights work, but only if i hold the switch back without letting it...
Dodge had a problem with bad headlamp switches. They will get hot enough to melt the switch and the connectors. Replacement switch comes with new connector and pigtail wires which require cutting the old wires and soldering new ones to the old and seal with shrink tubing. Do NOT attach with crimp connectors (**** connector). Take the extra effort to do a proper solder job on them. The switch is pricey - mine cost me about $100 from the dealer.
Jun 21, 2010 | 2000 Dodge Ram 1500 Truck
I need to switch on my nokia 6233 without using the button!
Dear, new buttons is not very expensive, so if you want another solution then open your mobile phone and solder your old button because the problem is that your old button is unsoldered.
ok Thaks
May 08, 2010 | Nokia 6233 Cellular Phone
When I start my 2004 5.7 hemi during colder weather the oil pressure gauge reads o .If I shut it off and restart it reads normal pressure
You don't say if you live in a colder climate and if this happens more in colder weather, but what it sounds like is the oil pressure switch is either partially plugged with oil gunk or thick oil when you first start your engine the oil pressure does not read as its partially plugged but as soon as you shut it off the oil redistributes itself in the pressure tube and reads the pressure. The easiest fix is to replace the old pressure switch with a new one but before you install it remove the old one and cover the threads where it goes with a rag and have a freind crank the motor over until oil comes out the threads and then install the new switch. Thanks Don
Oct 16, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
LG Env phone swap
If you go to the Myverizon online and click Phones&Devices under the support tab, it will lead you to a page where you select the type of phone you have. Once you have done that, the next page should say "Activate Phone" on the left side. Click that and you will get step by step instructions to switch phones, activating the new one.
May 21, 2009 | LG enV VX9900 Cellular Phone
Jabra BT150 Wireless Headset Logo
37 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
