Question about XM Radio (XMP6000)
Where do you send these to be fixed?
I have an XM2go that I need to have repaired. Do you know where I can send this out to have it fixed? The bottom piece that accepts the charger is loose and it will not charge. I think it needs to be soldered back in. Thanks!
  • 32 Answers
I would suggest any reputable audio store that does installations or any electronic repair shop. If I'm not mistaken, I think your XM2go is made by Pioneer. Therefore, I would suggest going to Pioneer's website and look for an authorized repair facility near your area. I hope this helps...good luck.
Posted on Jun 13, 2007
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
Intermittent headphone jack
Cheap and dirty way to fix it is to buy a 'headphone splitter' and plug it into the radio; when you get it 'just right" superglue it and hold it in position. Then you can use the two other plugs for your headphones until those two wear out. Ugly, but efficient way to fix it without tearing apart the radio, which has surface mount parts and is very difficult to solder to.
Dec 09, 2009 | Audio Players & Recorders
Turn on fm transmitter for Pioneer Inno XM2GO
Have you gotten it fixed? You did have it in a car dock, right?
Aug 18, 2009 | Pioneer XM2go Inno Satellite Radio...
On/off switch doesn't work. Can't get XM2Go to turn on
if you have an extended warranty on it i would send it back and have them take a look at it
Feb 27, 2009 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Xm2go
It occured to me after plugging it into the car adapter and turning on the car ignition. I ended up sending the unit to Panasonic and they sent me another. This must be a known issue.
Aug 10, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Repair of XM Radio
edie,
did you find a place to fix for xm radio? i have a similar problem.
thanks.
dan collison
Jun 13, 2007 | XM Radio (XMP6000)
Display of recorded programs does not match the program playing
There is a very small reset button under the back cover. You will need a small paper clip to reach the button. It is located in the upper left hand corner. The button is not under the batt., it is about 2" above the screw on the side. I don't know if this will solve your problem, but it should reset your radio to its default settings. Good Luck!
Apr 29, 2007 | Tao XM2go Satellite Radio Receiver
Car Audio & Video Logo
121 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
