Question about Microsoft Windows XP Media Center Edition 2005 for PC
Windows XP Default theme deleted
Started up my computer and it was operating with the Windows Classic theme. A bit disconcerting because I hadn't changed it, so I decided I'd change it back. The Windows XP theme seems to be gone from my computer. I'm running Windows XP Media Center. Help! I want my theme back.
  • Anonymous Feb 24, 2009
    back.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
U Must Use TuneUp Utilities>Styler n See if there is ur Theme -
If not Copy From C: From someones PC n Put it In Ur PC -
Will Work Sure :
Helped:
Posted on Jan 14, 2009
  • 903 Answers
This happened to me once on my other computer, I don't know what caused it, maybe service pack 2 that I installed but I don't know. Anyway i just rebooted and then the themes were back and I could change it again.
I hope this helps
  • Debs
    Debs Jan 14, 2009
    if that didn't work try restoring your computer to an earlier date when it was working as you liked it. Go to Start>acessories>system tools> system restore and select a date when you know your comptuer was working correctly. After the computer reboots this should be reolved. I hope this helps
  • Debs
    Debs Jan 14, 2009
    sorry it should have said, Start>all programs>acessories>system tools>system restore
Can't apply any original theme on XP
if you have a xp cd, do a fix operation of the systeme.
1- insert the cd
2- chose repaire option "not new install"!!!
Sep 09, 2009 | Microsoft Windows XP Professional SP3 Full...
How to set windows vista theme as default theme?
right click to my computer click properties click advance look for the performance click sittings and check best performance.
May 26, 2009 | Microsoft Windows Vista Ultimate Edition
Themes are not working
I can just guess , as there's not much information, I wonder if you have changed the graphics adapter settings from 32-bit to 16-bit ? or have chosen an alternate theme ?
right-click desktop and select personalize
click window color and appearance
click open classic appearance
select scheme and apply .
if you have a independent graphics card please go into the menu and make sure it's set at 32 bit color . good luck
Apr 15, 2009 | Microsoft Windows Vista Ultimate Edition
Theme Failing to work.
Go to Restore..
Menu details:
start==>all programs=>accassores=>system tools=> system restore...
give ur installation date...thanks.........
Mar 25, 2009 | Computers & Internet
How to fix windows xp look that shoud egzist in my sys. anymore,it only can wiew in classic windows mode
You want XP to look like when you first got it and not in classic mode, am I correct? If that is the case, do the following:
  • Right click on your desktop and select Properties
  • Go to Themes tab and select Windows XP and press Enter
That should bring you back your screen. If that did not help, then do the following:
  • Right click on my computer and select Properties
  • Click the Advanced tab
  • Select Visual Effects tab
  • Chose either Adjust for best appearance or you can let Windows decide what's best for your system.
Finally, if that does not work go into Control Panel --> select Administrative Tools --> Services. Look for Themes in Services to make sure that is is both set to Automatic and that the services is started.
Mar 20, 2009 | Microsoft Computers & Internet
My system was chenged the instal of xp theme original window,but it opens only in classic window
Right click on the desktop anywhere that there are no icons. Click on 'Properties' at the bottom of the menu that will have appeared. By default you will be at the window to set your theme. In the Theme field, click on the dropdown button at the right side of the field and select the Windows XP theme. Click apply and then OK to close the window.
Good luck, and please let me know how this works out for you.
Spoem
Mar 20, 2009 | Intel Computers & Internet
Desktop theme changes at startup
That's not supposed to be a problem... When you log in to your account windows loads your personal settings, as well as other programs, so it's supposed to take time. Windows probably has the theme set on default so it would show that while your settings are loading. That or you've got a virus... But... if you think your computer is unusually slow then that's a different problem. Try cleaning up your hard disk space and doing other sorts of stuff, like scanning for viruses to make it run faster.
Jan 18, 2009 | ASUS Eee PC 1000H Laptop
Window XP Home SP3
go to control panel, administrative tools, computer management, services and applications, services, look for themes - if it is not started, start it - if it works, goto the properties of the theme service and set to automatic
G'luck
Oct 24, 2008 | Computers & Internet
Microsoft Windows XP Media Center Edition 2005 for PC Logo
283 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
