Question about Xerox DocuColor 12 Printer
Smughes os streak on print out
Red lines on print out
  • Logan Chadwick
    Logan Chadwick May 11, 2010
    Could you give me more info other than "red lines on print out"
    Novelist:
  • Xerox Expert
  • 297 Answers
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
May 05, 2014 | Xerox 6180MFP/D Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Red toner streak on prints
Most likely you need to replace the red drum. If that doesnt work the developer housing is bad. Most likely though the red drum is bad,
Jan 14, 2009 | Xerox DocuColor 3535 Copier
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Xerox DocuColor 12 Printer Logo
124 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
