Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Fault code AL10
The dishwasher is not washing the dishes - looks half washed!
Someone said it was to do with a heating element problem?
The helpful engineer said I needed to find out what the exact problem was before calling him back!!!!
I called an engineer after checking with hotpoint what the fault code was. Hotpoint advised that it was either a faulty heating circuit and I had to check the heating connections and timer (impossible unless you call an engineer).
Anyway, the fault turned out to be something to do with a water feed (I can't remember the technical name). There wasn't enough pressure coming through a particular valve as it was stuck in a semi-closed version, consequently the heating element wasn't switching on as it wasn't 'sensing' enough water pressure.
Valve has been fixed, and the dishwasher is now doing OK! For the time beginning at least.......
Posted on Jan 15, 2009
My hotpoint ultima FDW85 - is displaying the code AL10 what does this mean (bought second hand with no manual
I believe that this means "Heater element open circuit" Symptoms are thayt the machine will fill with water but then will not wash because it's waiting for the element to start heating the water and it can't.
Jul 25, 2011 | Dishwashers
Our hotpoint fdw60 won't wash properly if at all water goes in but it does not seem to wash and we get a code of AL10 too
AL10 means open circuit in heating circuit. ie not heating which will also explain poor wash results.
can be a fairly involved job and should be left to someone who knows what they are doing.
on other hand could be as simple as a broken wire inside the door skin, just remove and give all the wires a good tug.
Jul 11, 2011 | Hotpoint Dishwashers
I have a kenmore ultra wash quietguard 3 . It fills but not enough to cover the heating coil. It washes poorly and leaves schmutz on the dishes. I have checked all the sprayers. They are not clogged. ...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 22, 2011 | Kenmore Dishwashers
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
Dishwasher
How to Buy
heatman101
Feb 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
Hi, I have an LG LDS4821 dishwasher and it appears to stop working properly. The dishes don't seem to be cleaned at all. It seems like the spray arms are not spraying the dishes as the dishes are still...
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | LG LDS4821 24 in. Built-in Dishwasher
We have inherited a bosch WFF2001 washer> It starts washing but does not rinse or spin. We have left it an hour washing but goes not further.
hi sir  i thinkKeeping the dishwasher's sprayer arms, strainers, and water pump clean will help deter problems before they begin. Here's how to check on these important features.The heating element is used to help dry the dishes. In most dishwashers, the heating element fits around the screen in the bottom of the tub housing; it looks like an electric oven element. The heating element doesn't malfunction often, but it can burn out. If you suspect a faulty element:
thank u..................................please rate
Sep 11, 2008 | Bosch Washing Machines
Hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Feb 13, 2008 | Dishwashers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
299 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
