Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Hello there... I have an WD3200ME-01 external HD.. its working, when linked by cable to the pc then the comuputer recognizes it, the light is on... however I cannot get into the HD? when I click it then it says "insert the disk" or a problem occured... Is there anything I can do about this???? have lots of data inside and need it. I bought it officially in Thailand on vacation....and will not get there anytime soon... thanks a lot
  • Lal Mohan Jan 24, 2009
    I have WD3200ME (Western Digital 320GB) external USB hard disk. When I plug this into the USB port, the lights on the disk burns immediately. However after few seconds, I get the message "USB Device not recognized". I have tried connecting the device in all the available USB ports of my computer. Has anyone found a solution for this?
  • SgtGordo Apr 19, 2009
    Same problem with same unit. I note that the WD web site for this unit only displays products with the WD logo on the black plastic case. The unit I have displays no logo, and was built in Thailand. I think the solution to this problem is to either buy only products with the WD logo, or bypass products made in Thailand. I had a similar problem with an external Seagate Free Agent, product of Thailand.
Same problem, same unit.
Posted on Jul 26, 2010
My 500GB Elements external hard drive is not being recognized by my computer
check usb cable first might try another cable to be certain it's not communications
and afterwards, you might consider running this utility to optimize your ext drive
Jun 16, 2012 | Computers & Internet
Harddrive not working. When it's plugged in it shuts down after a few seconds. I see a light flicker inside but it isn't sustained.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 10, 2011 | Western Digital My Book Essential 500GB...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
WD3200ME?
Here are the differences
WD3200TN has
Compact design
USB Powered
Sync & Encryption Software
Backup Software
Remote access
Soft Touch Finish
Capacity Gauge
WD3200ME has
Compact design
USB Powered
Apr 09, 2009 | Western Digital My Book Essential 1TB...
Western Digital 120GB Hard Drive not Connecting
change the hd from external case. . the chip in the case is bad.. or the hd.
hd can be taken out.. open it if its out of warranty to test it directly to pc cable inside.
May 04, 2008 | Computers & Internet
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
2,010 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
