Question about LG KU990 Viewty
I have just replaced my viewty screen as it was broke.. However now i have no pictures etc just a black dark bluish screen.
  • lyndsey_stru Jan 14, 2009
    Hi, Yes i reconnected it all and it seem's to work i musct of not did it correctly. However now the black on the screen IE the writing seem's more gray than black, and the buttons on all the right side don't work. (the lock button-Camera-etc) Thanks for for your help
    Problem Solver:
  • 4 Answers
Is the screen tape touching connectors properly
try restarting the prosess again and let me know
Posted on Jan 14, 2009
  • hotprofits Jan 15, 2009
    no problem m8 try just making sure buttons line up right b4 putting it together m8
    sound like there out of line a mm
Samsung UN39HF5000F No Picture Has Sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Dec 14, 2016 | Samsung Televison & Video
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
Left side of screen is dark
When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
Feb 14, 2011 | Philips Televison & Video
Screan gone black, but the phone works
Your LCD screen is broken. If you have insurance on the phone, you can have the phone replaced. If not, you have voided the warranty by breaking the screen.
You can find a replacement screen at:
http://cgi.ebay.com/LCD-Display-Screen-for-LG-KU990-KU-990-KE998-Viewty_W0QQitemZ120405276035QQcmdZViewItemQQptZPDA_Accessories?hash=item1c08b6b583&_trksid=p3286.c0.m14
Instructions for taking apart the Viewty are:
http://disassembly.wordpress.com/2009/08/03/lg-viewty-ku990-disassembly/
IF YOU ARE NOT COMFORTABLE TAKING APART YOUR PHONE...DONT! Take it to someone that is. Remember, if you have insurance on your phone, they will not replace it if it has a cracked screen, they will replace it if it is lost.
If I have helped you, please give me a good rating. It allows me to help others. Thank You.
Aug 07, 2009 | LG KU990 Viewty
Photo's go dark after taken them
You have to turn the ISO to 800 which is located on the camera settings and when you take pictures a red light will appear and you will get perfect quality
Feb 12, 2009 | LG KU990 Viewty
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55 inch hdtv rear projector
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Feb 13, 2007 | Casio Exilim EX-S500 Digital Camera
Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Jan 03, 2007 | Sony KP-53S65 53" Rear Projection...
Black LCD Screen
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Aug 31, 2006 | Fuji FinePix F601 Zoom Digital Camera
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
