Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wayne dalton garage door is humming but wont open
It sounds like the motor may be going out, but we have only had the garage door for 4 years. It is model number 5BWS-A372U. Any suggestion on how to fix or if the company will stand behind it?
  • 4 Answers
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Posted on Jan 15, 2009
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Wayne Dalton DoorMaster Model BDOr 2000 door will close but then goes back up immediately. How do I adjust it. Nothing is blocking the closure?
The Wayne Dalton Doormaster design is a mess. I've had two of them in my house for 10 years, with numerous repeat problems.
What you are experiencing is a need to recalibrate the door, but the underlying cause is that a linear potentiometer becomes non-linear, and the calibration drifts. Once this starts happening, it will continue to be a problem until you buy a new potentiometer, or clean the one you have. If you are handy, it isn't too hard to do.
Two other Doormaster problems are when the DC electric motor carbon brushes wear sand clog up the commutator, causing the motor not to run. Another problem can be corrosion on the back of the circuit board that causes erratic operation, but can be fixed by scraping the corrosion off the board.
If anyone still is having any of these problems, post here and I'll do a detailed writeup on these fixes.
Terry
Jan 25, 2013 | Sears Craftsman LiftMaster Chamberlain...
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door issue
stepper motor needs to be reprogram by a tech
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
824 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
