Question about Zenith B27A11Z 27" TV
Help my set comes on then off. once i unplug the set from the outlet and plug it up again it comes on and then back off each time.
    Scholar:
  • 68 Answers
Your TV swithes itself off, probably to standby to protect from doing further damage. If you, or an experienced friend have any idea of the power supply voltages in the set, then get him to monitor each voltage when you switch on. Bear in mind the chassis metal may be live at 120 to 300 volts, and keep clear of the line output transformer. You may have to use the old type analogue volt meter with a pointer and scale, as the reading may only be there for a second or so. Remove any dust so that you are sure to see where to connect probes. There is usually an electrolytic capacitor for each voltage to connect the probes to. If the negative side is at chassis potential, then clip the negative probe to this. If no reading is measured across one of the electrolytic capacitors, then this, or another component, may be short circuit. The rectifier diode or a fuse will have blown, or be overloaded. The fault is detected by protection circuits, which cause shutdown to standby. If you can locate the protection circuit, its input data (voltages) may give you a clue where to look.
Posted on Jun 19, 2007
    Novelist:
    Champion:
  • 236 Answers
Sounds like you have an overload somewhere in your TV. It's not a direct short in the power supply itself but one of the circuits powered by the power supply. Most likely it is in the horizontal output circuit. Stargazer
Posted on Jun 16, 2007
Tv won't turn on
Have a shop look at it, there is a power relay that either is causing this or something right around it is, seen this about five times over the last ten years in Hitachi sets. I had one customer who had it connected to a wall switch and from time to time had to unpower it several times but once on it was fine.....
Dec 15, 2012 | Hitachi 51F500 51" Rear Projection...
Display & lights go out after use when door is opened, can uplug unit, then plug back in and display & lights work again until next use
If it's doing that u may have a short in the cord somewhere I would try while plugged in next time u use it don't unplug it but next time it goes out move cord a little bit n see if it comes back on if so that's the problem r u getting bad connection somewhere try another outlet too
Feb 10, 2012 | Samsung SMH7185STG Stainless Steel...
Every few months the compressor will not come on. It will try over and over but will not start. At the same time, the light does not come on when the door is opened. I can unplug the power cord and plug it...
Hi!!
The lighting circuit and the compressor electrical circuit are independent from each other once they go past the electrical terminal block, (where the power cord connects to, on the back of the fridge).
For the description of the problem, it sounds like you have a loose power cord terminal connection at the block, a defective power cord or power outlet.
Try connecting the fridge on the other power outlet (if it is connected to a regular dual outlet ), some times the contactors, over time, tend to loose the grip on the power cord plug and the contact is lost, when you remove the plug from the outlet and plug it back in, restores temporarily the contact again, or, the plug itself can be defective and loses contact. Replacing the power cord and using a different power outlet (even if it is a dual) will let you know if that where the problem was. If that doesn't solve the problem, let me know and will do some more troubleshooting.
Good Luck and keep me posted.
Jan 10, 2011 | Refrigerators
I have a PF erorr code on my oven screan
"POWER FAILURE" code, unplug the power from the range for 20 minutes or longer, plug back into the power outlet, set time and if the micro-processor didn't take a hit during the power failure you should be up and going once again.
GOOD LUCK !
Aug 26, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I unplugged my model RP5435B clock and when I plugged it back in to the outlet the time will not set. How do I set the time again?
FIRST!!! Replace the "standby" 9V battery. Then unplug and replug... you should now be able to set the time.
Feb 03, 2010 | Audio Players & Recorders
My HP Officejet 6500 wirless works with incoming faxes as long as autoanswer is on. However once it goes into sleep mode after sitting idle for a few minutes, it will not. If a fax comes in it will not...
Solution one: Plug the product directly into a wall outlet to make sure the power source functions correctly.
1. Disconnect the power cord from the back of the product.
2. Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
3. Reconnect the power cord to the back of the product.
4. Try to print again from the computer.
NOTE: If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not allow enough voltage to reach the product.
If the issue persists , continue to the next solution.
Solution two: A semi-full reset returns the following settings to the factory defaults:
· User menu settings · Telephony parameter values · Country and language selection · Fax memory · Fax journal information · Speed dial and broadcast lists · Personal header information · Junk file numbers
1. Press the Power button to turn off the product, and then unplug the power cord from the wall outlet.2. Disconnect the power cord from the back of the product, and then wait 20 seconds. 3. Plug the power cord into the wall outlet. 4. Press and hold # and 6 while reconnecting the power cord to the back of the product. Press the Power button to turn on the product, and then follow the instructions that display on the control panel to select the product settings.
Oct 02, 2009 | HP Officejet 6500 Wireless All-in-One...
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Router keeps going off
Try to hard reset the router and re-flash or update the firmware of the device. Make sure to know all the internet settings before resetting the router so you can recongure it again.
You can ask your router manufacturer on where to download firmware.
Hope it will hel you.
Oct 08, 2008 | D-Link Vonage-enabled Wireless Router...
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  1. Unplug the power supply from the wall outlet.
  2. Unplug the power supply from the back of the printer.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Zenith B27A11Z 27" TV Logo
52 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
